compatiable power supplies for Xantech IR blocks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-17-2003, 01:38 PM - Thread Starter
raiders's Avatar
Do you need to order the Xantech power supplies or will an appropriate voltage power supply from Radio Shack? Specifically the 789-44 block says it uses either the 781RG or 782-00 power supply, does anyone know what the equivalent RS Power supply would be?
Go Oakland Raiders!
raiders is offline
post #2 of 2 Old 02-18-2003, 05:41 PM
Colm's Avatar
Liked: 94
You can use any power supply that can provide the appropriate current and voltage. It needs to be a regulated supply that puts out between 11.5 V and 13 V under load. You also need to make sure that it has the appropriate size plug and the plug polarity is the same as the connecting block. Doesn't seem to be a standard for plug polarity. Center pin is positive.
Colm is offline
Closed Thread Home A/V Distribution
