HDMI Handshake issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2016, 03:02 PM - Thread Starter
tidwelr1's Avatar
Quoted: 253 Post(s)
Liked: 70
What's more likely the cause of a hdmi handshake issue? The hdmi cable or the receiver the signal is being routed thru?
tidwelr1 is offline
post #2 of 5 Old 01-29-2016, 03:16 PM
jautor's Avatar
Quoted: 1307 Post(s)
Liked: 836
If it's a <15' cable, the device(s)... Longer cables, could be either - replace with a shorter cable temporarily to see where the issue lies...
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #3 of 5 Old 01-29-2016, 03:23 PM - Thread Starter
tidwelr1's Avatar
Quoted: 253 Post(s)
Liked: 70
appreciate the response. The cable in question isn't more than 15' feet but it is running thru a wall about 4-5 feet. I'm getting flicker even without a source playing....just marantz logo showing on the screen.
tidwelr1 is offline
post #4 of 5 Old 01-29-2016, 07:30 PM
Neurorad's Avatar
Quoted: 230 Post(s)
Liked: 145
Agreed, try a different non-Redmere short cable.
Neurorad is offline
post #5 of 5 Old 01-31-2016, 03:51 AM
Joe Fernand's Avatar
Quoted: 354 Post(s)
Liked: 210
'What's more likely the cause of a hdmi handshake issue?' - if only it were that simple!
'I'm getting flicker even without a source playing....' - sounds more like a physical problem rather than a handshake issue.
What gauge is the cable you are using? A heavy cable could be causing a problem staying seated in one or other of your HDMI sockets!
Simplify the system down as far as possible, disable any up-conversion in the AVR, disable Deep Color (if an option) in the AVR, try a different Input socket on the Display device, try a different HDMI cable, ensure all devices are running the latest Firmware.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is offline
Reply Home A/V Distribution
