Any HDMI switch support 4k + HDR + HDCP 2.2 + IR remote control? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-02-2016, 04:24 AM - Thread Starter
jpb-ca's Avatar
Are there any reliable 4->1 or 5->1 HDMI switch that provides 4k, HDR, support HDCP 2.2, and are IR remote controllable? Thanks!
jpb-ca is offline
post #2 of 10 Old 11-02-2016, 06:54 AM
oldavman's Avatar
Check this one out from Monoprice:
Blackbird product # 152634K Pro 5x1 HDMI® Switch with HDCP 2.2 Support and IR
Hope this helps
oldavman is offline
post #3 of 10 Old 11-02-2016, 07:05 AM
oldavman's Avatar
Hope this helps
Also, have you considered getting an AVR. Many include everything on your shopping list and the prices are coming down every day. Just a thought.
oldavman is offline
post #4 of 10 Old 11-02-2016, 10:39 AM
Quoted: 25 Post(s)
Liked: 2
harveyAV is offline
post #5 of 10 Old 11-02-2016, 04:50 PM
Joe Fernand's Avatar
Quoted: 281 Post(s)
Liked: 164
Our HD41-ARC is now available as the UHD41-ARC - supports 2160p, 60fps, HDCP 2.2, HDR and ARC.
You can control via IR plus it has an IR Passthru blaster socket to allow you to pass IR to connected Sources if the kit is in a cabinet.
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #6 of 10 Old 11-16-2016, 09:06 AM
Dhalmo's Avatar
Quoted: 124 Post(s)
Liked: 60
Joe
Where can I buy this product? Did a google search and could not find it.
Dhalmo is offline
post #7 of 10 Old 11-17-2016, 02:03 AM
Quoted: 281 Post(s)
Liked: 164
Octavainc.com
Joe
post #8 of 10 Old Yesterday, 03:56 PM
x19
Liked: 0
Octavainc.com
Joe
Hijacking this dead thread. I purchased the UHD41-ARC-IR based on reading posts on the forums here and am having difficulty with it and my Vizio p65 and Roku Premiere+. Is a firmware upgrade needed in order to make this work?
x19 is offline
post #9 of 10 Old Yesterday, 03:57 PM
x19
Liked: 0
To clarify, problems with HDCP errors blocking 4k HDR content.
x19 is offline
post #10 of 10 Old Today, 02:32 AM
Quoted: 281 Post(s)
Liked: 164
Hi x19
Drop a note to info@octavainc.com
Outline the system and the problem and the support team will work with you to resolve any HDCP errors.
Joe
Reply Home A/V Distribution
