experience with CYP PU-44XL-KIT HDMI Matrix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-26-2017, 09:23 AM - Thread Starter
Liked: 0
Hi All,
Im looking into the 4x4 matrix in the title 9CYP PU-44XL-KIT.
Im after a matrix i can run over my normal network. By this i mean from matrix in to managed switch(s) and then receiver at TV, Projectors etc.
Does the above support this? i can't find much info on it. i know i could go for the 'just add power' solution but id like the matrix in one box and not as separate transmitters.
The switch's can run multiple VLANs so thats not an issue. just want to find one that can support what i need before forking out the $$$.
andyt2005 is offline
post #2 of 5 Old 08-26-2017, 10:24 AM
jautor's Avatar
Quoted: 1330 Post(s)
Liked: 852
Originally Posted by andyt2005 View Post
Hi All,
HDBaseT is NOT Ethernet! All of the HDMI matrix products use the same wiring (cat5e/6) as Ethernet, but they are completely different uses. You cannot connect HDBaseT devices to any Ethernet infrastructure. That will be the same answer for any "HDMI Matrix" or "HDBaseT" product.
The products you are looking for, if that's really what you want, are called "HD over IP" or "HDMI over IP", and the JustAddPower products are very good examples of that.
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #3 of 5 Old 08-26-2017, 10:26 AM
Joe Fernand's Avatar
Quoted: 404 Post(s)
Liked: 224
HDBT Matrix - no that will not integrate with your managed Switch. You would need to unbundle some cables from your network and provide a direct link from the RJ45 Output on the Matrix to the RJ45 Input on the Zone Receiver (if your cabling is good you can go usually via a Patchbay - though ideally you try to avoid them).
HD over LAN - you can use on a managed Switch, our Pro DSX is one solution to consider, http://www.octavainc.com/PRO%20DSX_H...processor.html
Joe
Octava Inc. Multi-cast HD over LAN solutions.
Ruipro UK and EU Sales and Support
The Media Factory. Residential and Commercial system Design, Consultancy, Installation, Supply and Integration.
Joe Fernand is offline
post #4 of 5 Old 08-27-2017, 06:02 AM
Yellow Jacket's Avatar
Quoted: 63 Post(s)
Joe
Is a 'patchbay' different from a panel?
What would the issues be?
To Hell with Georgia...
Yellow Jacket is offline
post #5 of 5 Old 08-27-2017, 06:23 AM
Quoted: 404 Post(s)
Liked: 224
Patch Bay/Patch Panel - same thing
'What would the issues be?' - no issue, intermittent signal or no signal. HDBT is pretty robust but can still be tripped up by one too many connections in the cable run. Many HDBT systems will accommodate a Patch Panel without any issues but always best to be aware that there is some potential for problems if you are unlucky.
Joe
Reply Home A/V Distribution
