Will a switch work here? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Falcon2915
  • 1 Post By jautor
post #1 of 4 Old 08-30-2017, 03:58 PM - Thread Starter
Liked: 0
My ISP feed comes into a metal box in the laundry room. They expect me to install my router in that box but I don’t want to because the metal box is not located for optimal WiFi coverage (and IT’S METAL! that can't be good...). Also, I want to put the router on a shelf in the (more centrally located) pantry where I have several NAS drives and a printer. There are three Cat6 Ethernet cables in the metal box going to the pantry, the master bedroom, and the living room. If I put a switch in front of my router will the Satellite TV box, the master bedroom Ethernet outlet, and the router all work as expected?
crick616 is offline
post #2 of 4 Old 08-30-2017, 04:03 PM
Quoted: 29 Post(s)
Liked: 2
From looking at your diagram, you have the network switch and router backwards.
The input from your ISP has to go into your router first to negotiate packets, then forward to the network switch.
You could get round the problem by installing the router in the box where the ISP has dropped your incoming line (turn off it's WiFi radio), then run a separate access point from your better located switch outlet.
dan4081 likes this.
Falcon2915 is offline
post #3 of 4 Old 08-30-2017, 09:34 PM - Thread Starter
Liked: 0
Thanks for the quick response. Unfortunately I don't want to put the WiF router in a remotely located metal box. Its radio signal won't cover the desired area.
crick616 is offline
post #4 of 4 Old 08-31-2017, 09:25 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Put the router there and turn off the WiFi (like Falcon suggested)... Then put one or more WiFi access points wherever makes sense in the house.
dan4081 likes this.
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
Reply Home A/V Distribution
