Sony Receiver to Russound Home Audio System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-06-2017, 11:12 AM - Thread Starter
Liked: 0
Hi folks! I've read a few items on here about getting power to my Russound audio system throughout my home, and that information was helpful. After getting the right power adapters to the Russound A-4HD panels, I now have power to the A-KP panels throughout the home. In comes my next hurdle
I have a Sony STR-DN840 receiver which doesn't have any RCA audio outputs that I can tie into the Russound A-4HD audio input panel. What is the recommended way to get audio out of the Sony receiver to the home audio system? Do I get an adapter to go from speaker wire to RCA? I figured I'd ask the pros here before I went and started buying cables. Thanks in advance!
hunt_ak is offline
post #2 of 3 Old 09-06-2017, 11:53 AM - Thread Starter
Liked: 0
Or should I just bypass the use of the Sony receiver altogether and get a dedicated bluetooth receiver with RCA outputs that can just live in this space? We likely will only use bluetooth audio for the home sound system, so maybe just simplifying the whole thing would be good?
If this is the case, does anyone recommend a decent and relatively inexpensive audio receiver with RCA audio outputs that will suffice for this system?
hunt_ak is offline
post #3 of 3 Old 09-08-2017, 09:53 AM
RBalwinski's Avatar
Quoted: 70 Post(s)
Liked: 50
I am a Sonos Fan, but this will work for your needs, Can't do much better than $35 either.
https://www.google.com/chromecast/audio/
Projector: Epson Home Cinema 5030UB
Receiver: Pioneer Elite VSX-90
Bluray: Sony BDPS5500
Screen: Elite Screens ezFrame Series, 100" 16:9 AT AcousticPro1080P3 FF Screen
+ 6 Sonos Connects, Dayton Audio MA1240a Multi-Zone 12 Channel Amplifier
RBalwinski is offline
Reply Home A/V Distribution
