AV Rack in Garage Closet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-12-2017, 05:28 PM - Thread Starter
cw4u's Avatar
I have a closet off of my garage that is about 4ft x 12ft. It's insulated on 3 sides. Could this be a suitable location for an AV rack? I had thought about running an 6-8" hvac drop to keep the room somewhat conditioned.
cw4u is offline
post #2 of 2 Old 09-13-2017, 08:09 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
You cannot mix air between the garage and the house. Against code because of CO risk. Dropping an HVAC duct wouldn't help anyway, as it would only cool the closet when the system is actually running (and for only some of the year).
You may be able to just circulate air between the closet and the garage with some 24/7 fans and enough vent panels to allow "fresh" air into the closet. But unconditioned spaces like garages are not recommended for expensive electronic gear - the dust, humidity, etc. are not good for longevity.
Now, if you can seal up the room, and provide both HVAC drop and a return, so that it becomes part of the conditioned space of the house (and not part of the garage air), that would work. You'd put an exhaust fan in the HVAC return (and likely one in reverse on the supply) to circulate air through the HVAC ductwork, effectively dumping the warm but conditioned air into the house. I would not do this without consulting someone to ensure it's up to code and safe (because of the garage).
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
Reply Home A/V Distribution
