AV setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-13-2017, 07:28 PM - Thread Starter
Liked: 0
AV setup
I'm building a log cabin and have prewired for 3 tv's and 6 ceiling speakers (4 inside and 2 on the porch. We would like to have audio from the main TV into the 4 living room speakers (2 front and 2 rear); and occasionally listen to music from the two speakers on the porch. Maybe even have the TV sound on all 6 speakers. I have all speaker wires and TV cables run from a small closet area. TVs all work, just would like to add sound. Have 6 Klipsch R-1650-C speakers in ceiling. Just not sure what receiver to get so I can control the audio how I like. Used to be that receivers had multiple speaker selectors. Those days look to be gone. I was also wondering how hard it would be to do a theater setup in the main room. Do I only need to add a center channel? I can run an extra speaker wire under the house if necessary? Any advice would be helpful. All my audio experience is 20+ years old with 2 a 4 speaker setups.. Never had home theater.. Thanks
edswan is offline
post #2 of 3 Old 09-13-2017, 08:37 PM
smoothtlk's Avatar
Quoted: 82 Post(s)
Liked: 45
Sounds like you have the beginning of a "5.1" typical home theater setup.
You would generally add a Center Channel and a subwoofer to round out the TV watching experience.
Many receivers support a "B Zone" for the porch speakers. Denon is one brand. Their mid cost plus offer the second zone.
smoothtlk is offline
post #3 of 3 Old 09-14-2017, 07:41 PM - Thread Starter
Liked: 0
Thanks.. That was my guess after some reading.. But just hated to buy equipment that wouldn't do what I needed.
edswan is offline
Reply Home A/V Distribution
