IR Repeater -- extending the Mits Big Screen Built-In - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-22-2003, 09:48 PM - Thread Starter
jeffster's Avatar
Has anyone had any luck extending the reach of the built-in IR extenders on Mitsubishi HDTVs? (I have a 65907.)
I had a xantech system in my prior house, but I'm thinking that since the Mits has this feature built in, all I'd need to do is figure out a way to extend the length of the cables it uses to about 20' and I'd be set.
Will the signal carry that far with acceptable strength with the built-in Mitsubishi signals? Anyone done this?
Failing this, any recommendations for a repeater?
-- jas
jeffster is offline
post #2 of 2 Old 08-23-2003, 09:18 AM
audiblesolutions's Avatar
20 feet. No problem. I have done that with a Mitsu
Since it's ir I would bet you send the ir 100 ft. but I haven't done that with a Mitsu. I have sent ir 500 ft with a control system.
Alan
audiblesolutions is offline
Closed Thread Home A/V Distribution
