Outdoor IR Extender/Repeater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-28-2003, 07:22 AM - Thread Starter
Booka's Avatar
I am setiing up outdoor speakers that will be mounted on an exterior wall under the overhang. This exterior wall forms on the other side the interior rear wall of the garage, where a receiver and CD player are located. I would like to be able to control the receiver and CD playerl from outdoors using their respective remotes. The outdoor location is on the north side of the house and does not normally receive direct sunlight where the speakers will be located. My thought is to mount some type of IR receiver near the speaker locations, i.e. on the exterior wall and under the roof overhang. This distance from the exterior wall to the receiver and CD player is minimal, i.e. less than 10 feet. The front of the receiver and CD player face 180 degrees opposite of the exterior wall.
I would like a reasonably priced solution to repeating the IR signal from the remotes to both of the audio components. Your thoughts on this issue are welcome.
Booka is offline
Closed Thread Home A/V Distribution
