F Type connector to Component - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-17-2004, 08:09 AM - Thread Starter
doggiedog's Avatar
I'm looking to install cabling in my wall and was wondering if I could use a coax wall plate and terminate it with a component connector for use with a front projector.
I was originally thinking of using a component wall plate but the coax route seems much cheaper.
Denon X4100W | B&W CM6 S2 Front | B&W HTM2 Center | B&W 601 S3 Surround | Hsu VTF-3 Mk5 HP Sub
doggiedog is offline
post #2 of 7 Old 06-17-2004, 08:42 AM
hometheaterguy's Avatar
Sure, it would work. Both cables are 75 OHM. You could do it one of two ways: Terminate with F-connectors and use a F-to-RCA adapter. http://www.partsexpress.com/pe/showd...number=090-283 is a good place to find these adapters. Or, buy the compression tool that allows you to crimp RCA fittings on RG6 and use a triple plate for your PJ run.
A veteran is someone who, wrote a blank check Made Payable to 'The USA, ' for an amount of 'up to and including their life.'
hometheaterguy is offline
post #3 of 7 Old 06-17-2004, 04:00 PM
Brent McCall's Avatar
Read this thread.
http://www.avsforum.com/avs-vb/showt...hreadid=413102
Brent McCall
Not A Dealer
Brent McCall is offline
post #4 of 7 Old 06-17-2004, 07:31 PM - Thread Starter
doggiedog's Avatar
Thanks all.
One question though.
I though RCA was different from component. Would I get the same performance out of an RCA connector that I would out of a component connector?
post #5 of 7 Old 06-17-2004, 10:34 PM
audiblesolutions's Avatar
I suspect you are confusing the words composite ( as in video ) and component. Most consumer component video connections are RCA female. A few companies, like Integra, also provide BNC connections. The difference is technical and irrelevant to 480p signals at any rate. Feel free to use RCA connectors for your component video connections.
Alan
audiblesolutions is offline
post #6 of 7 Old 06-18-2004, 07:29 AM - Thread Starter
doggiedog's Avatar
I'm confused now.
I thought RCA connectors were composite.
I plan on using the component cable to connect to an HDTV cable box.
post #7 of 7 Old 06-18-2004, 08:02 AM
Foosinho's Avatar
RCA is the connector type. They are used on composite, and some (most) component, cables. Some component hookups on some hardware uses BNC connectors.
Actually, more accurately, a cable is a cable is a cable. There is no difference between a "composite cable" and a "component cable".
Foosinho is offline
Closed Thread Home A/V Distribution
