ChannelPlus question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-06-2000, 08:30 PM - Thread Starter
jasonl99's Avatar
Ok, I just did a prelim hookup of a channelMaster 3025. I've inserted a second DirecTV signal onto an very unused channel.
The picture is OK. DirecTV's guid is not particularly good, but passable. But volume is a problem. Volume for the "real" channels is much higher than it is for the ChannelPlus.
Any suggestions?
jasonl99 is offline
post #2 of 2 Old 06-06-2000, 10:11 PM - Thread Starter
jasonl99's Avatar
Ok, let me answer my own question.
I first looked for a more clear station. Put it on that. The picture improved markedly, but the audio didn't. Then I thought about how I have it hooked up...
The system is hooked up through a Yamaha 2095 receiver using the second zone. I'd never even looked at the zone 2 remote, but sure enough, there's a volume control. Pumped up the volume a bit, and I'm set.
Pretty cool. Picture is very good, in fact crystal clear. I'd highly recommend the ChannelPlus 3025!
jasonl99 is offline
Closed Thread Home A/V Distribution
