Least expensive rear speakers solution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-19-2000, 12:26 PM - Thread Starter
DBCooper's Avatar
I'm in the market for rear speakers for a small room. Quality is secondary to ease of wiring. I cannot run new wires easily, but have three kinds of existing wiring that connect across the room.
1. Power
2. Telephone
3. CAT-5
I'll need to buy speakers, too, because I've misplaced the unpowered pair that came with my Pioneer AM/FM/amp.
What's the least expensive solution? Stereo wireless seems pretty expensive for this use. http://www.avsforum.com/ubb/confused.gif
DBCooper is offline
post #2 of 4 Old 08-20-2000, 02:10 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
For about $100 each, you can purchase balanced line drivers and receivers. This will allow you to use the CAT5 for your speaker cabling. www.audiocontrol.com
D. Erskine
DEsign Cinema Privee
www.DEsignCinema.com
Imagine what you could do, if you could do all you imagine.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #3 of 4 Old 08-20-2000, 10:18 PM
David Richardson's Avatar
I can't believe I'm going to suggest this but since this will work and your quailty is secondary. Here we go.
Cat 5 has 4 pair of wires
Use one pair for the + of the left rear and the 2nd pair for the - of the left rear.
Use the third pair for the + of the right ear and the fourth pair for the - of the right rear.
Now before I get flammed I just want to say I would never do this. As an installer I'll always find a way. (My disclamer and Flame retardent)
Dave
Watch HDTV!!! Nothing else comes close!
David Richardson is offline
post #4 of 4 Old 08-21-2000, 07:33 AM
David Guill's Avatar
I can't believe you mentioned it either. There are times when no action is the best alternative. DBCooper you may be better off waiting until you have a larger budget to work with. Until then be satisfied with the audio from your TV.
David Guill is offline
Closed Thread Home A/V Distribution
