Long AV cables (25 - 30ft) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-07-2000, 07:19 AM - Thread Starter
jerndl's Avatar
Quoted: 32 Post(s)
I need to run cables (1 video, 2 audio) with RCA plugs from my modulator to my satellite receiver. It is about 25 to 30ft. Can I use an RG6 cable using an "F" female to RCA male adapter for the video? How about audio? I would prefer to use something I can get locally and since the signals are going through a modulator, I don't think it's necessary to buy high (high cost) quality custom made cables. Does anybody have any other ideas for reasonably priced cables that I can get quickly. Thanks.
jerndl is offline
post #2 of 4 Old 08-07-2000, 08:46 AM
bb80301's Avatar
I have a run of at least 25 feet from the A/V receiver in my family room to a modulator in the basement. I used RG-6 coax with F to RCA connectors (just like you described) for video and light gauge speaker wire with RCA connectors for audio. Works great in my application.
bb80301 is offline
post #3 of 4 Old 08-07-2000, 04:14 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 109
RG-6 Quad shield (one aluminium foil shield and one copper) with a solid copper center conductor (most 'cheap' RG-6 uses copper clad steel).
D. Erskine
DEsign Cinema Privee
www.DEsignCinema.com
Imagine what you could do, if you could do all you imagine.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #4 of 4 Old 08-21-2000, 06:21 PM
zzzzdoc's Avatar
Just ran 100 foot run of RG-6 Quad Shield from my Replay TV to a modulator with the F to RCA adapters on each end. Signal looks great -- better than I expected.
HTH, YMMV, but 25-30 feet shouldn't be a problem with good cable.
If it won't produce 500 watts per channel through a direct short, you need more power.
He who laughs last...Thinks slowest.
zzzzdoc is offline
Closed Thread Home A/V Distribution
