Component signal conversion? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-11-2000, 10:47 AM - Thread Starter
anson's Avatar
This seemed like the best place to ask this:
What's the best way to convert a 3-wire progressive component signal into a RGB-HV, 5-wire component signal? We have a progressive DVD player here that needs to be connected to a plasma panel.
-anson
anson is offline
post #2 of 7 Old 10-11-2000, 10:53 AM - Thread Starter
anson's Avatar
Here's a device that does the exact opposite of what I need:
VGA to component converter
http://www.smarthome.com/77706.html
Where's the counterpart???
anson is offline
post #3 of 7 Old 10-11-2000, 02:33 PM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 109
Component to RGBHV is available from Extron Electronics.
D. Erskine
DEsign Cinema Privee
www.DEsignCinema.com
Imagine what you could do, if you could do all you imagine.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #4 of 7 Old 10-19-2000, 06:46 PM
michaellucky's Avatar
extron is very expensive
michael@keydigital.com
michaellucky is offline
post #5 of 7 Old 10-24-2000, 05:27 PM
Greg C's Avatar
Monstercable via entech has a new box that will convert compsite, s-video and component to RGB. It retails at about $999.
Greg C.
www.pghcustomht.com
CEDIA University Designer CAT Member
CEDIA University Instructor
Crestron DMC-E
Greg C is offline
post #6 of 7 Old 10-24-2000, 05:53 PM
Quoted: 64 Post(s)
Liked: 109
As is the Plasma screen he's attempting to connect to.
D. Erskine
[This message has been edited by Dennis Erskine (edited 10-24-2000).]
CEDIA Chairman
post #7 of 7 Old 10-25-2000, 10:31 AM
Not only is it expensive (this type of product should not cost more than $300, no matter which projector you are using) and in addition to on HDTV forum they report extron has sync problem on CVC-200. So now you recommend a mercedes that cant take you from point A to point B, while the rest of use a honda without any problems.
Closed Thread Home A/V Distribution
