RG-6 Crimping? - AVS Forum | Home Theater Discussions And Reviews
Old 10-23-2000, 02:18 PM - Thread Starter
adamtraidman's Avatar
From each room in my home, I have two coax lines running to a central distribution box in the garage. For some bizarre reason, the installers decided (before I owned the home), to leave half of the coax runs (the second line from each room) without ends. Therefore I have to attach standard ends on 6 cables. I have crimped RJ45 and RJ11 ends on before, but never coax. Must I buy a special crimping tool, or can I do it by hand with any common tools like pliers? Seems like such a shame to spend $20+ on a coax crimper when I only need it this one time. (knock on wood)
Adam
adamtraidman is offline
Old 10-24-2000, 07:36 AM
bwolff's Avatar
$20 will not get you a good crimpier. Either rent one and buy good ends, or buy ends at your local hardware store. Then crimp them with the inside jaw of a pair of pliers working them around slowly not just one hard squeeze. Then hope you don't get to much leakage, or the end doesn't come off.
Bwolff
~~~~~~~~Bwolff~~~~~~~~
My Theater
Champagne tastes with a beer budget
bwolff is offline
Old 10-30-2000, 04:56 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 101
There are two tools you'll need. First the stripper...it cuts and strips the ends of the wire properly for the F connector. Second the crimper. You should determine what coax you have (Rg-59, RG6, or RG6 Quad shield). RG-59 and RG6 use a different stripper (actually, most strippers have settings for both). RG59, RG6, and RG6QS use different F connectors.
D. Erskine
DEsign Cinema Privee
www.DEsignCinema.com
Imagine what you could do, if you could do all you imagine.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
