Where to get Distribution Panels? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-25-2000, 09:41 AM - Thread Starter
Hans_Moleman's Avatar
I'm looking for a distribution panel to install in 'mission control'. Specifically I want to install 2 coax, 1 phone, and 1 ethernet distribution system in a wiring panel I'm intending to put in the closet of my spare bedroom. It will also need AC power to run the ethernet router/hub and coax feed amps. Some day I'll probably also add an X10 and/or home security system.
I've found one place that has some fairly generic metal boxes as well as some of the distribution modules (http://www.futurehomesystems.com/shop/dept_sw2.html). Anybody have any other options? I'd also like to hear any tips or advice anyone has on installation, sizing of the panel, and anything else I should do now (before I get started) to minimize pain when I go back to add things later.
Matt
Hans_Moleman is offline
Closed Thread Home A/V Distribution
