How to get TiVo signal to basement theater? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-26-2001, 02:18 PM - Thread Starter
mflaster's Avatar
Hi all,
I am currently putting together a home theater in the basement. I have a TiVo upstairs, which I use a modulator (the cheapest I could find - http://www.smarthome.com/7715a.html ) to put its signal on channel 91. Currently, its signal upstairs (which has to travel through a whole bunch of splitters) is definitely noisy.
My question is - if I have a more direct run to my theater (sending the coax through only maybe 1 or 2 splitters), how good will the signal be? Given that this is going to go on a big screen (through an HTPC and dTV), I want to avoid signal degredation (on an already imperfect signal) as much as possible. I *could* run an S-video cable directly (I guess I'd convert the S-video into 2 composite cables because it's maybe a 50-100 ft run), but that would be a pain.
Will there be much degradation with a modulator compared to S-video cable? And does the modulator itself make a big difference?
Thanks in advance!
Mike
mflaster is offline
post #2 of 4 Old 01-29-2001, 08:18 PM
Steve13's Avatar
I have no experience with this particular modulator, but I do use a good quality Channel Plus modulator in my theater to pipe my TiVo and DVD to 3 other TV's throughout the house. Signal quality is good. Reducing the number of splitters will definitely improve picture quality. You can also amplify the signal along the way, which might help.
Another alternative is to use a higher end video distribution panel instead of the splitters. I use the Channel plus 8200 ( http://www.channelplus.com/coax_pan.htm ) and it works very well. Good prices and service at Worthington Distributing www.worthdist.com. Worthington has a lot of the same stuff as Smarthome, but a lot cheaper. For example, the 8200 was almost $100 cheaper at Worthington.
Steve
Trying to figure it ALL out (and hope I never do!!)
Visit our dedicated home theater, The City Cinema.
[This message has been edited by Steve13 (edited 01-29-2001).]
Steve
Steve13 is offline
post #3 of 4 Old 01-31-2001, 12:43 PM - Thread Starter
mflaster's Avatar
Thanks for the replies!
My understanding is that the whole house video distribution panels require direct coax home-runs to all the outlets. That would clearly eliminate splitters and a lot of problems! I *guess* I could rewire things... How is IR handled? Is it integrated with the 8200, or do you need a separate item?
For IR distribution, I currently own an Xtra Link 2 (http://www.smarthome.com/8197.html), which does low voltage signaling over the coax. But that also has trouble jumping splitters. Is it possible to get an amplifier that will work with the low voltage signal too?
I'm not sure if I'm ready to jump in with both feet yet... Is there any issue if you couple 2 long coax cables together, say 50' + 30'? Is that much worse than a single 80' coax? If I could extend my coax cables, maybe I could get all the cables into 1 room in the basement...
Mike
mflaster is offline
post #4 of 4 Old 02-02-2001, 08:10 AM - Thread Starter
mflaster's Avatar
I just wanted to let everyone know I found a very informative article about running coax over Cat5:
http://www.belden.com/products/tpvutp85.htm
Mike
mflaster is offline
Closed Thread Home A/V Distribution
