How are you interfacing IR to X-10? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-07-2001, 12:22 PM - Thread Starter
spepin's Avatar
I have been searching for an X-10 IR-543 interface with no luck. Is this product either too new, or too old to find anywhere? What are others using as an interface between IR (Pronto) and an X-10 system?
Also, I currently only have a few X-10 devices installed, so changing to another similar, but better solution is not out of the question.
Any suggestions?
spepin is offline
post #2 of 6 Old 03-07-2001, 04:19 PM
rfoye's Avatar
I bought an IR543 2 months ago from http://www.hometech.com/
There were a number of sources. Try searching for IR543, not IR-543.
Rich Foye
rfoye is offline
post #3 of 6 Old 03-07-2001, 05:18 PM - Thread Starter
spepin's Avatar
spepin is offline
post #4 of 6 Old 03-08-2001, 04:37 PM
truaudiophile's Avatar
Here is a nice wall mounted controller to send some codes by IR control.
I'm not sure what kind of IR control you need.
http://www.smarthome.com/12061.html
truaudiophile is offline
post #5 of 6 Old 03-08-2001, 05:40 PM - Thread Starter
spepin's Avatar
Thanks. I saw that one, but I don't want a wallswitch unit. The IR543 can be hidden in the cabinet and reached via a Xantech emitter. I found one and have ordered it through SmartHomeUSA.
Thanks again guys!
Steve.
spepin is offline
post #6 of 6 Old 04-23-2001, 12:25 PM
westly197's Avatar
I also got mine at smarthome.com, smart home part 4040 at $29.95, but got them to match a price of 23.19 from MCM Electronics order number IR543 ( http://www.i-mcm.com/Search/search4-...equestid=19455 )
My Home Theater
westly197 is offline
Closed Thread Home A/V Distribution
