Simple question: IR remote control extender - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-16-2001, 11:23 AM - Thread Starter
Paulo's Avatar
Hello, now that I have put a screen in front of all my equipment, my IR control doesn't work anymore, because there's no path for it....
what shall I do now? Which are the equipments brand/model that I can use for that?
Paulo
Paulo is offline
post #2 of 5 Old 04-17-2001, 07:09 PM
jeremiah75's Avatar
I use the Hot Link Pro by MicroSmith. My equipment rack is located in a closet in the back of the room and the Hot Link receives the ir signal. You can read more about it at their website.
http://www.hot-link.com/pro.html
There are also ir repeaters from Radio Shack, but I didn't have good luck with them. MicroSmith was very helpful when I called them, and willing to provide information on others products that might help. That makes them a good company in my book.
jeremiah75 is offline
post #3 of 5 Old 04-18-2001, 07:19 AM
Matthew's Avatar
You may also want to look at Xantech.
http://www.xantech.com
Matthew is offline
post #4 of 5 Old 04-19-2001, 11:14 AM - Thread Starter
Paulo's Avatar
thanks for your replies. I bought Russound system and I will test it today.
Best regards,
Paulo
Paulo is offline
post #5 of 5 Old 04-23-2001, 07:48 PM - Thread Starter
Paulo's Avatar
I want to put my comments on the Russound system: I used 1 connecting block model 847, 1 1257 IR Receiver and 3 845 IR Emitter. I had to buy a regulated 12V Power supply.
Well, I can say that the IR receiver is very sensible, that I cannot have any fluorescent light, because it remains continuously on, so I can't control anything.
Paulo Wang
Paulo is offline
Closed Thread Home A/V Distribution
