Openhouse Systems? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-22-2001, 05:57 AM - Thread Starter
mrwilson's Avatar
Anyone have any experience using this companies product? http://www.openhousesystem.com
I only considered them because I've had good luck with Channel Plus equip. in the past. Plus I really like the all-inside one box look to it. Can any share good or bad about these?
Anyone online sell this stuff? Thanks
mrwilson is offline
post #2 of 6 Old 04-24-2001, 05:22 PM
truaudiophile's Avatar
Mrwilson, I can express only good opinions in relation to your question. There are a wide variety of modules, all are excellent quality. Fit and finish are good. A wide variety of cable knockouts are on the box to configure for many applications, and the best of all-the prices. I you are going to add a network router and network modem, purchase your own and mount them to the back with self-taping screws and strap. Or you could just let them rest on the bottom of the cabinet. All of the Network/structured wiring box makers are overpriced and behind in technology for the LAN stuff. I have used a half dozen other products and I have decided to stick with OPENHOUSE.
truaudiophile is offline
post #3 of 6 Old 04-25-2001, 09:22 AM
bb80301's Avatar
<font face="Verdana, Arial" size="2">Originally posted by truaudiophile:
...and the best of all-the prices...</font>
Truaudiophile:
Where have you purchased from? I saw the stuff at CES, but haven't found it yet at any of my favorite dealers.
Thanks and regards
BB80301
bb80301 is offline
post #4 of 6 Old 04-25-2001, 05:01 PM
jcm
jcm's Avatar
The AVAD Group distributor/sales rep in your area should carry it. In the northeast that's Jarmac/Custom Works. I'm pretty sure the ADI distribution chain of home security etc. also carries the line.
jcmitch
jcm is offline
post #5 of 6 Old 04-25-2001, 05:53 PM
David Richardson's Avatar
ADI carries it. Its just Channel Plus gear. Great Stuff.
Dave
Watch HDTV!!! Nothing else comes close!
David Richardson is offline
post #6 of 6 Old 04-25-2001, 06:16 PM - Thread Starter
mrwilson's Avatar
I talked to http://www.basshome.com/ on the telephone and he said they have the entire Openhouse Systems catalog, its kinda hard to find on the web site but its there under Complete Systems, Home Automation
mrwilson is offline
Closed Thread Home A/V Distribution
