Theater Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-25-2001, 02:28 PM - Thread Starter
Nadee Akhter's Avatar
I am getting my basement done and allocated about
15x15 or 15x20 area for home theater. Would this size
be OK or is it too small?
Any advice on type of wiring should be done.
Planning of putting a Projection system.
Nadee Akhter is offline
post #2 of 3 Old 05-25-2001, 07:45 PM
David Richardson's Avatar
Welcome to AVS Forum.
I have a den/theater thats 15x22. The screen being in the middle of the 22 and the fireplace in the middle of the 15. Viewing angle is very wide in my house. Some like long narrow seating. Its room usage and personal preference.
Wiring... Need more info like proj. model and equipment list DVD,VCR etc........
Dave
Watch HDTV!!! Nothing else comes close!
David Richardson is offline
post #3 of 3 Old 05-25-2001, 08:49 PM
truaudiophile's Avatar
Nadee,
Also post your question in the Theater Construction section of this forum. You will probably get more responses. Good luck with your new room--Fun project!
truaudiophile is offline
Closed Thread Home A/V Distribution
