Connecting two Xantech IR hubs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-27-2001, 10:05 PM - Thread Starter
Jym
Jym's Avatar
I have two IR networks in my house that I want to connect. I have one that is used everywhere buy my home theater. It has recivers around the house that connect into a HUB which then has a bunch of emitters. I then have 2 receivers in the theater that connect to a hub with emitters.
I now want to connect the two. I want the IR receivers around the house to be able to control the equipment in the theater.
I am thinking that I would connect two wires as an emitter from the house HUB and connect to input in theater. There is usaully three wires used but I assume the other is for power. The three connections are V+, ground and signal. Which two should I use? Seems obvious to use signal. But what is the second, V+?
Any help appreciated.
IR Receiver ---> IR HUB ---> emitter connection --> IR HUB
-Jym-
Jym is offline
post #2 of 2 Old 05-28-2001, 09:44 AM
David Richardson's Avatar
If I'm reading your request correctly, you want to make your 2 IR systems one zone.?.?
If this is the case take all the sensor wires and tie the together. Use a 12VDC 1AMP power supply to power all 4 sensors as well as the hub. You can come off of one emitter port and go into the other HUB as well. I would use a Xantech amplified connecting block if you have intermittent operation.
Dave
Watch HDTV!!! Nothing else comes close!
[This message has been edited by David Richardson (edited 05-28-2001).]
David Richardson is offline
Closed Thread Home A/V Distribution
