Radio Shack A/V sender - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-31-2001, 12:06 AM - Thread Starter
ripster's Avatar
I just bought the SONY Ultimate TV box and would like to send the A/V to another room without breaking down the walls. An installer suggested a new Radio Shack wireless A/V sender. For $100 bucks I guess I could try it. Any other suggestions out there??
ripster is offline
post #2 of 3 Old 05-31-2001, 08:59 AM
simonduz's Avatar
if you decide to go the wireless route save some money and get the x10 entertainment anywhere kit.(it's the same product) http://www.x10.com/products/x10_vk57a.htm
You can pick this up for $49 after the $20 voucher which is worth the money. I have been using one of these to distribute my Tivo to an upstairs bedroom that was not wired properly and it works fine for what I need it to do. You will need some way of sending the remote signal though.
  • No tears, please. It's a waste of good suffering.
simonduz is offline
post #3 of 3 Old 06-01-2001, 07:03 PM - Thread Starter
ripster's Avatar
Simon -
Looked like a great deal to me. Got the Video and Remote sender (IR), plus a Palm Pad for $87 bucks!! Thanks for the tip!!
I am sending an a/v signal from DSS box to RPTV in another room. How's the Pic?? Do you still get Surround Sound?
ripster is offline
Closed Thread Home A/V Distribution
