Outdoor Remotes RF-IR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-08-2001, 04:15 PM - Thread Starter
mlivesay's Avatar
Hi All,
I'd like to be able to control some of the IR-driven HT equipment in my home while I'm out in my backyard. Specifically, I'd like to be able to adjust the volume level of the amp driving my outdoor speakers, along with turning on/off X-10 lights and such, while sitting in my pool or on my patio.
Question: Does there exist an attachment that I can place over an IR learning remote (like the pronto) that will transmit the IR signals as RF to an internal RF receiver, which will then convert them back to IR? I would want to connect emitters to the RF-IR unit to control my various HT equipment. An alternate solution would be an IR learning remote that transmits RF directly to a similar RF-IR base station.
I would need some decent range (like 100' or so), as our backyard is very deep.
Stupid question: Am I correct in assuming that I need an RF solution like the above? I would expect that IR doesn't transmit well in daylight or outdoor environments.
Thanks in advance for any suggestions.
Mike
mlivesay is offline
post #2 of 4 Old 07-08-2001, 06:00 PM
TimS's Avatar
Take a look here. I use these on jobs all the time. The 150 feet is a little optimistic. More like 100, regardless it cant hurt to try this as the least expensive route.
http://smarthome.com/8220a.html
All the worlds a stage, some of us just have better seats.
TimS is offline
post #3 of 4 Old 07-08-2001, 07:40 PM - Thread Starter
mlivesay's Avatar
Thanks a bunch, TimS - that's exactly what I was looking for!
Best,
Mike
mlivesay is offline
post #4 of 4 Old 07-08-2001, 09:42 PM
TimS's Avatar
No problem,
Please let me know if you have any other questions about this or related audio areas. Email me directly if you like.
TimS is offline
Closed Thread Home A/V Distribution
