One Amp -> 4 pairs of speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-09-2001, 11:36 AM - Thread Starter
jdt
jdt's Avatar
So I have speaker wires run to several rooms in the house. At this time I don't want to buy a Kustom/Niles/Russound Multizone system. I just want to hear the same input in four locations.
So I was looking at getting either one of those speaker selector/volume controllers or a speaker distribution panel (seen them at smarthome.com).
My two questions are:
(a) what do people think is the best solution for under $200?
(b) does anyone make volume control units (for use with Niles/Russound) that are external to the wall?
John
jdt is offline
post #2 of 2 Old 08-09-2001, 02:34 PM
John G's Avatar
John,
The Niles SPS-4, or speakercraft S4 impedance matching speaker selectors are both good products for your application and run about $99 retail at your local electronics retailer.
Volume controls like the Niles VCS-2D would work fine, or the Speakercraft VST-60 should work fine and run about $65 retail. They can be mounted in the wall using a single gang cut-in ring/retrofit ring which run about $1.00 at Home Depot. If you'd like to do a surface mount option you can just pick up a single gang surface mount box at Home Depot (choose the deep model) and install your volume control inside that. The cover plate will work normally. If you're going for an outdoor location, then grab one of their outdoor wet location covers at Home Depot as well.
-- John G.
-John G.
-John Gonzales
wwjd?
John G is offline
Closed Thread Home A/V Distribution
