Weatherproof Volume Control - AVS Forum | Home Theater Discussions And Reviews
Old 08-07-2001, 12:24 PM - Thread Starter
jerndl's Avatar
Quoted: 32 Post(s)
I am looking for a outdoor volume control. I have seen this Niles model at many places http://www.crutchfield.com/cgi-bin/S-DsINHmWWbQo/ProdView.asp?s=0&c=1&g=15230&I=1 90wvc1&o=&a=
The spec shows that it has power handling of 60 watts per channel. I plan on using a 100 watt/channel receiver (Yamaha RXV-992) and NHT OutdoorOne speakers. Is this going to be a problem? Can anyone recommend this unit or any other units? Thanks for the help.
Jay
[This message has been edited by jerndl (edited 08-07-2001).]
jerndl is offline
Old 08-08-2001, 06:17 AM
truaudiophile's Avatar
Russound also makes one. the model is the WALTx2. It has the ultramatch adjustable impedance matching. 126Watts power handling. 42WRMS continuous. The unit has quick connect terminals and is already housed in a grey weatertight enclosure. 12step attenuation with an "off" position. -j
truaudiophile is offline
Old 08-09-2001, 05:43 PM - Thread Starter
jerndl's Avatar
Quoted: 32 Post(s)
Any reason to pick one over the other? Also, is the power handling spec adaquate for these volume controls? Thanks.
Jay
jerndl is offline
Old 08-10-2001, 06:12 AM
Yes, These volume controls will work with your receiver.
