RG 179 cable. . .? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-07-2001, 08:26 AM - Thread Starter
ssnsltd's Avatar
Tried a search for/on RG179
Will:
Beldon (RG179)-E 83264 M17/94, MIL -C1755495 (W/ 75 Ohm BNC connectors)
work well to use as my cabling between my Extron109 to my Barco RGBHV (input4/5)?
David Ferris
Go Army!
Barco RetroGraphics801, Dishnet5000, Fosgate3A, Proscan 8680Z and Sampo 620 DVD, Mitsubishi HS-423UR SVHS, NHT speakers.
David Ferris
Go Army!
Barco RetroGraphics808, Pioneer PDP-502MX 50" Plasma, Dishnet 508 and 512, Fosgate3A,   and Sampo 620 DVD,, NHT speakers.
ssnsltd is offline
post #2 of 3 Old 08-11-2001, 08:08 AM
Tom Rosback's Avatar
David,
Depends on the length of the cable.
RG 179 is a high loss cable. Overall, as a rule of thumb, I wouldn't exceed 3 dB loss at 100 MHz. This will allow you to run 720p with no apparent degradation. This will limit your run length to under 30 feet.
Some 'experts' may say 3 dB at 100 MHz is too much attenuation, further limiting run length.
I'm using a similar cable, 25' long, with my line-doubled Sony 1272Q. I had to use the small diameter cable because my doubler uses a DB-15 connector in a DB-9 shell size. No way to fit RG-6 in there. The projector is still very much the limiting factor. Your Barco is a higher performance projector, YMMV.
RG 179 ATTENUATION:
Nominal
MHZ DB/100'
1 3.0
10 5.3
50 8.5
100 10.0
RG 179 is teflon jacketed, totally overkill for a non-avionics installation. PVC jacketd cable is much cheaper.
If you have the physical space, RG-6 is the video reference standard, with the attenuation characteristics below:
MHZ DB/100' MHZ DB/100'
5 0.67 400 4.00
55 1.60 450 4.26
211 2.87 550 4.71
270 3.24 750 5.59
300 3.43 870 6.00
350 3.72 1000 6.54
Tom Rosback
JVC RS 500, Stewart 106" Studiotek 130
McIntosh MC 2301 x 3, MC 602
McIntosh MX 151, C500T, MCD 1100, Oppo BDP-95
Sonus Faber Amati Futura, Amati Homage Vox, Proac Response 1sc
Nottingham Dias TT, Ace Space Arm, Sumiko Palo Santos cartridge
Tom Rosback is offline
post #3 of 3 Old 08-13-2001, 11:53 AM - Thread Starter
ssnsltd's Avatar
Tom,
Thanks for the reply, sorry I took so long to say so, I am in the Army and am Temp Duty away from home. . .
The run I am talking about is ~10'. I got some RG179 cables pretty cheep that had the BNC connecters already installed on one end. I have a generic BNC to BNC cable I am using now, just wondered if the RG179 would be better
David Ferris
Go Army!
David Ferris
Go Army!
ssnsltd is offline
Closed Thread Home A/V Distribution
