Home Networking Equipment - AVS Forum | Home Theater Discussions And Reviews
Old 08-16-2001, 10:24 PM - Thread Starter
Manex's Avatar
I'm just starting to build a new house and I want to wire the house with 10/100 ethernet. My builder only has UStec products in their lineup and they are way too pricey for what you get, so I've decided to do it myself. In addition, I already have a lot of equipment that I'd like to re-use, such as switches, print servers, and a router. I'm looking for manufacturers or suggestions for products I can use on the "built-in" side of the equation, such as ethernet patch panels on the walls etc. If anyone can give me some links or other information, I would really appreciate it.
Thanks in advance,
Eric
Manex is offline
Old 08-17-2001, 03:55 AM
Huckster's Avatar
From this thread on this board area: http://www.openhousesystem.com/telecom.htm
I haven't used these products but they sure LOOK good. http://www.avsforum.com/ubb/smile.gif
Huck
Huck
Huckster is offline
Old 08-17-2001, 12:01 PM - Thread Starter
Manex's Avatar
Thanks for the links and info... at least now I have somewhere to start looking!
- Eric
Manex is offline
Old 08-17-2001, 06:38 PM
gpershall's Avatar
www.smarthome.com is another good source for the do-it yourself person. I ordered most of my cable,connectors,wall outlets,etc. when I wired my new home a few yrs ago.
gpershall is offline
Old 08-17-2001, 10:13 PM
truaudiophile's Avatar
manex_ You are right about the UStec stuff. It is expensive, but one of the best. The stuff is only installed by the trained dealer.
I have used the OpenHouse stuff and I am happy with all of their gear. They are using the Channel Plus stuff. Good Quality and mix of products.
Check out www. siemon.com for some more wall plates, outlets and items. They require minimal tools for installation and are easier to install. They have everything! The only disappointment is the lack of outlet plate colors. Not good for decorators. Their white is off-white compared to the Pass and seymoore plates and outlets.
Have fun and run lots of Cat5e to the Home office for the router with the Print server. -j
truaudiophile is offline
