Looking for small entry-level distribution panel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-21-2001, 10:46 PM - Thread Starter
sbourgeo's Avatar
I'm getting a bit tired of the rats nest of telco/coax in my basement, so I am looking for a low-end distribution panel to initially handle 2 telephone lines (cat 3) to 4 locations and 1 coax cable TV line to 4 locations.
I also need it to fit into a small space (8" wide) and expandability is a plus.
The Leviton 47691-C seems like a nice fit since it comes over-configued to handle my phone and coax needs and will have a cover to keep prying hands away. It is a bit expensive at $160-$170 though.
http://www.smarthome.com/8630e.html http://shop.store.yahoo.com/asihome/47ecdispanki.html
I can also just get a bare Leviton Advanced Home Telephone and Video Panel ($84 at Home Depot) and mount it to the wall on its side.
http://www.smarthome.com/865104.html
Does anyone have any experience with either of these products or perhaps a nother product that is small, and inexpensive?
Steve
Philips 312-03 30 hour
2.0.1-002-000
[This message has been edited by sbourgeo (edited 08-22-2001).]
sbourgeo is offline
post #2 of 12 Old 08-22-2001, 07:08 AM
woowoo's Avatar
Take a look at Milestek (www.milestek.com)
Page 8 of there print catalog
They have several solutions
good luck
Studio Broadcast Engineer
KET
Broadcast Engineer
woowoo is offline
post #3 of 12 Old 08-22-2001, 12:37 PM
Max Spivak's Avatar
Take a look at HomeTech: http://www.hometech.com/, lot's of good descriptions, etc.
Max
Max Spivak is offline
post #4 of 12 Old 08-22-2001, 04:30 PM - Thread Starter
sbourgeo's Avatar
Max,
Thanks for the link... Good tutorial-type stuff for a newbie like me.
At this point, I'm probably going to go for a all-in-one solution unless I can find a company that'll put together a package for me.
Otherwise, I'm not sure that the components would even neatly fit in the box or do what I need them to do.
Steve
Philips TiVo 312-03 30 hour
2.0.1-002-000
sbourgeo is offline
post #5 of 12 Old 08-22-2001, 09:40 PM - Thread Starter
sbourgeo's Avatar
I tried poking around on their web site when researching this, but it didn't seem very intuitive to me.
I've requested the print catalog, so that should help a bit.
Steve
2.0.1-002-000
sbourgeo is offline
post #6 of 12 Old 08-27-2001, 03:47 PM
fdelacou's Avatar
I have some experience with the leviton you are talking about. It is really nice and easy to use but keep in mind that you will be able to do only one phone line since cat 3 is using 6 positions on the 110 connector. The solution could be to connect only 4 of the siz wires and in that case, it should work properly.
Hope this help,
Frederik Delacourt www.bigfoot.com/~fdelacou/hometheater/main_en.html
Frederik Delacourt
My home theater: http://membres.lycos.fr/fdelacou/hometheater/main_en.html
fdelacou is offline
post #7 of 12 Old 08-27-2001, 05:39 PM
stevel's Avatar
Check out your local Home Depot! I was there yesterday and they had the Leviton boxes and some of the accessories at prices considerably lower than I've seen elsewhere. (And I just splurged for smarthome.com's OnQ "starter kit" - it's nice, but I since realized I could have paid less elsewhere, such as http://www.worthdist.com/
Steve
Steve
stevel is offline
post #8 of 12 Old 08-27-2001, 07:44 PM - Thread Starter
sbourgeo's Avatar
Hope this help,
Thanks Frederik,
I only need to connect 4 conductors (2 for each phone line), so I think I'll be all set.
I have not been able to find much info about this particular model. I'm wondering if it's discontined or something...
Does this box have punch out panels at the top or bottom, or do you have to feed all wires through the back?
Steve
2.0.1-002-000
sbourgeo is offline
post #9 of 12 Old 08-27-2001, 07:46 PM - Thread Starter
sbourgeo's Avatar
Steve
Hi Steve,
I did check the Leviton stuff out at Home Depot. Almost all of the boxes seem to be about 14 inches so they can be put between wall studs. I need to get something a bit skinnier.
I could mount one of the bare panels they sell if I decide to go that route.
Steve
2.0.1-002-000
sbourgeo is offline
post #10 of 12 Old 08-28-2001, 08:01 AM
fdelacou's Avatar
The Leviton enclosure has 6 knock out holes. 3 on top and 3 at the bottom. Each hole has two different sizes depending if you remove the inner circle or the outer circle.
Was that your question?
Frederik Delacourt
Frederik Delacourt
fdelacou is offline
post #11 of 12 Old 08-28-2001, 12:32 PM
fdelacou's Avatar
The enclosure that I have and bought at home depot is not the same. A picture of the one I'm talking about could be found at http://www.bigfoot.com/~fdelacou/leviton.jpg
Note that the enclosure has the possiblity to be attached between two studs or could be attached on the wall directly. The spacing in then smaller.
Sorry for the confusion.
Frederik Delacourt http://www.bigfoot.com/~fdelacou/hom...r/main_en.html
[This message has been edited by fdelacou (edited 08-28-2001).]
Frederik Delacourt
fdelacou is offline
post #12 of 12 Old 08-28-2001, 09:25 PM - Thread Starter
sbourgeo's Avatar
Frederik Delacourt
Yes, it's not easy to tell from the picture
47601-C
I guess the knock out holes are in the cover itself...
Steve
2.0.1-002-000
sbourgeo is offline
Closed Thread Home A/V Distribution
