What does YOUR wiring cabinet look like? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
Old 09-01-2009, 01:48 PM
WonHung's Avatar
Here's a slightly older pic of my network rack setup:
Since then, I built a dedicated room which has insulated walls around it so I can install a cooling system in the future. The heat loading from the gear and the servers I run makes it prohibitive to keep the door to this area closed.
WonHung is offline
Old 07-12-2010, 06:47 PM
djkyle65's Avatar
[/quote]
Where can i get the 1 hole rack wire mounting strut?
Also are there any more threads similar to this I would love to see more ideas.
djkyle65 is offline
Old 07-12-2010, 09:55 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
It's a Middle Atlantic Lacer Bar LBP-1A... Available anywhere Middle Atlantic stuff is stocked, and they're cheap!
http://www.altex.com/Middle-Atlantic...A-P139834.aspx
Jeff
jautor is offline
Old 07-13-2010, 08:43 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
mmm...rack porn
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Old 07-23-2010, 12:15 PM
Dmtalon's Avatar
Warning... Cellphone picture...
This is down in my basement, it's a craigslist server rack, I did all the LV wiring. Eventually I'd like to build a small room around it (i.e. close it off) but right now its just sitting down there by itself.
HTD MA2535 12 channel amp
Home Built HTPC
Octava HDMI CAT5 Matrix
HR21 Directv HD DVR
HR20 Directv HD DVR
Xantech IR Block
SMC Network Switch
Patch Panel
On top for now is my DSL router, WRT54G, Security DVR, and Cordless Phone base that's hooked up to Magic Jack on the HTPC.
Dmtalon is offline
