In-ceiling speakers and insulation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-13-2006, 10:10 PM - Thread Starter
Mike_W's Avatar
I'm about to install in-ceiling speakers in several rooms which have blown-in insulation above the ceiling. What's the best way to handle the insulation? Should I just move the blown-in insulation back on top of the speakers after I install them? Should I lay a piece of fiberglass insulation on the speaker first and then move the blown-in insulation back into place? How are others handling this?
Mike_W
Mike_W is offline
post #2 of 8 Old 04-13-2006, 11:21 PM
IVB
IVB's Avatar
After cutting a hole and forgetting I had blown-in directly on top, which resulted in a huge pile of insulation on my kitchen floor, I went to the attic, moved it to the side, mounted the speaker, then just moved it back over.
It sounds fine, but your post makes me realize that fiberglass on top may be a better path to avoid any potential ramifications from the blown-in getting into places it shouldn't.
Yes, I'm "that" Home Automation Guy.
IVB is offline
post #3 of 8 Old 04-14-2006, 08:54 AM
ATOH's Avatar
Mike_W
Yes, or a back box. Even the Dynamat ones would work, and they're flexible.
http://www.dynamat.com/products_arch...l_dynabox.html
ATOH is offline
post #4 of 8 Old 04-14-2006, 11:31 AM
bigpapa's Avatar
Back boxes will make the speaker sound better. Short of that, put up some batted instulation behind.
bigpapa is offline
post #5 of 8 Old 04-15-2006, 11:27 AM
vince2's Avatar
Mike, if you use Triad speakers (a local company to you) they come fully enclosed. This improves the sound quality as well.
vince2 is offline
post #6 of 8 Old 04-23-2006, 12:16 AM
tomciara's Avatar
Does simply enclosing the speaker make it sound better? If the enclosure is small and constricting to the movement of the woofer, I'd guess you to be just as well off with an "infinite baffle" - eh? The cubic volume of the enclosure is an issue in my opinion.
tomciara is offline
post #7 of 8 Old 04-24-2006, 11:40 AM
vince2's Avatar
For best results, the enclosure should be matched to the speaker, which is why I recommended the Triads. However, even a home-made box may help with the problems that in-wall and in-ceiling speakers face like poor bass response, phase cancellation and sound transmission into adjacent rooms. They can also prevent physical damage (ever see an attic after a re-roofing job?).
vince2 is offline
post #8 of 8 Old 04-24-2006, 12:40 PM
bigpapa's Avatar
You're right. Each speaker has an ideal/optimum cubic dimension. The manufacturer may actually give you that dimension if you call them.
I frequently create .75 cubic foot enclosures for speakers with 5.25 inch drivers. You might just go with that... we go to .8 cu feet for slightly larger speakers, and go to 1.2 cu feet for inwall subs (two 8" drivers). This is for some Bay Audio speakers, and I call tech support any time I install a new speaker model.
You might try tech support for your speaker, or just try one of the above dimensions. Use dense and heavy material, seal the enclosures, and insulate.
bigpapa is offline
Closed Thread Home A/V Distribution
