Steren Universal compression tool - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-23-2006, 12:33 AM - Thread Starter
v1rtu0s1ty's Avatar
I would like to know if someone has used this universal tool made by Steren, http://www.smarthome.com/849301.html
If so, do you it can work with this RCA compression connector, http://www.smarthome.com/8556c4.html
Please let me know.
Neil
v1rtu0s1ty is offline
post #2 of 4 Old 12-27-2006, 10:55 AM
johnson_sb's Avatar
I'm looking at that tool right now. Did you ever try it out? Or go with another tool? Any recommendations?
I have some F-conn connectors that I bought, but unfortunately, the cheap compression tool I bought (http://www.partsexpress.com/pe/pshow...51&rak=360-046) will not work properly with them. I think I need something adjustable like the one you mention.
Also got belden 1505F cable, which I think may end up giving me trouble since it has a stranded center conductor.
-Steve
johnson_sb is offline
post #3 of 4 Old 12-27-2006, 12:14 PM
R_Willis's Avatar
You need the connectors listed right under that URL link @ Parts Express to use with your "cheap" compression tool. They have F, RCA, and BNC available.
To use the F-Conn stuff, I'd say you need the F-Conn tool or maybe one that is compatible with their connectors.
R_Willis is offline
post #4 of 4 Old 01-03-2007, 12:26 PM
styxx_78's Avatar
v1rtu0s1ty,
Did you ever buy that tool? How is it? Have you terminated and F connectors with it and which ones did you use?
styxx_78 is offline
Reply Home A/V Distribution
