Not enough AC plugs in new panel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-24-2006, 06:24 AM - Thread Starter
amheck's Avatar
Quoted: 20 Post(s)
Hi everyone,
I am just about to the phase where I need to wire my home. I am planning on using the Leviton 28" panel, along with the 4 outlet block as shwon below.
THe problem is that most of my devices use wall warts for plugs. The coax amp, cable modem, router, and VoIP adapter will take up all 4 outlets, but I have no idea how these will all fit. Is there no other choice but to buy a power strip to go in there to give you more plug in room?
http://www.basshome.com/images_produ...ules_b9980.jpg
amheck is offline
post #2 of 10 Old 08-24-2006, 07:00 AM
indil377's Avatar
Make some jumpers out of zip cable and you could split the warts up on 2 different outlets. Just make sure you get zip cable big enough to carry the load.
Matt D. Sherer CET, CTS-I,ISF-C
indil377 is offline
post #3 of 10 Old 08-24-2006, 09:06 AM
robertmee's Avatar
I used something like these for that purpose: http://www.cyberguys.com/templates/s...productID=4189
BTW, I wouldn't waste your money on the leviton power strip. $45 for nothing. I used one in one of my panels, but then in my second panel just used a 8$ power strip.
robertmee is offline
post #4 of 10 Old 08-24-2006, 12:45 PM
DWScott's Avatar
I think Leviton would like you to use one of these:
http://www.basshome.com/images_produ...ower_b8438.jpg
It's a "Leviton DC Power Distribution Module 48212-DCS" and can supply power for up to six devices, and uses only one power outlet.
Neat idea, not sure if it works as advertised.
My new speakers have True Cognitive Dissonance Technology (tm).
"They'll always sound as good as you think they should!"
DWScott is offline
post #5 of 10 Old 08-24-2006, 12:48 PM - Thread Starter
amheck's Avatar
Quoted: 20 Post(s)
Yeah, I actually saw that. How do you know the supplied cords will work with my equipment, i.e. router, VoIP, etc. I think that might be used to ppower their own equipment, but I'm not too sure about other manufacturer's equipment.
amheck is offline
post #6 of 10 Old 08-24-2006, 12:55 PM
DWScott's Avatar
Not sure, really... if the plug sizes and total amps of needed by your equipment are correct, it might just work out.
I believe that alot of this electronic stuff is pretty tolerant of the power they get, but you'd have to find out for sure.
BTW, I have the 42" panel, and decided to run the big, fat, heat producing gear (like router, switch, cable modem, etc) from on top of a shelf right above the panel, rather than inside it. Made it easy to plug in, as well. It just didn't seem to be enough room, otherwise.
DWScott is offline
post #7 of 10 Old 08-24-2006, 02:19 PM
robertmee's Avatar
I use one of those in my Video Surveillance cabinet to drive all the cameras....You can only use them if the Voltage is the same for each device. You can't mix/match VAC and VDC and the transformer that comes with it provides 12VDC.
post #8 of 10 Old 08-24-2006, 04:09 PM
truaudiophile's Avatar
I have not used or Specified one of these little panels. Do the Transformers that come with them have a regulated output?
truaudiophile is offline
post #9 of 10 Old 08-24-2006, 04:26 PM
robertmee's Avatar
Beats me....Here's the nameplate:
MAXIM, Model MD571318, 120VAC, 13VDC, Class II Made in China
post #10 of 10 Old 08-26-2006, 12:35 AM
Andrew Wolfe's Avatar
I would use the liberators as suggested above. Otherwise, you can now get power strips that have plugs spaced for wall warts. Just put in 1 plus and mount the power strip behind your cabinet or rack.
Andrew Wolfe is offline
Closed Thread Home A/V Distribution
