Recommendations for Component Distribution Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-15-2007, 11:21 PM - Thread Starter
olp79's Avatar
I have a projector and a plasma tv, and would like to use the output from my receiver to send the component output to both display devices.
I've read that a splitter will degrade the signal, and that I need a component distribution amp.
Anyone have any recommendations on what I should get and, if it will degrade the signal any.
olp79 is offline
post #2 of 6 Old 01-16-2007, 03:22 AM - Thread Starter
olp79's Avatar
I tried to link to ebay but I wasn't allowed. If you paste this exact phrase, "Component Audio Video Distribution Amplifier 1 x 4", into ebay you'll find this product.
Is this any good? Or is the bandwidth to low for HD signals?
olp79 is offline
post #3 of 6 Old 01-16-2007, 08:53 AM
DennisBP's Avatar
I have an Audio Authority 9850 with two of the four runs 100' and the signal is excellent.
"I like to watch" - Chauncey Gardiner in Being There
DennisBP is offline
post #4 of 6 Old 01-16-2007, 10:37 AM
IVB
IVB's Avatar
How far are you going? I haven't heard of folks having PQ issues with Autopatch splitters, and there's many CQC'ers that use them to distribute component around their house.
Yes, I'm "that" Home Automation Guy.
IVB is offline
post #5 of 6 Old 01-16-2007, 01:41 PM - Thread Starter
olp79's Avatar
I have a run of 30 feet to the tv and 15 feet to the projector.
I also need a few more component inputs as my receiver only has 2.
Are there component switchers that have 2 outputs?
Are there receivers that have 2 component outputs?
It seems that a quality distribution amp can be quite expensive and it might be better to put the money towards a new receiver.
Did anyone look at the one on ebay, or is it just junk?
olp79 is offline
post #6 of 6 Old 01-18-2007, 11:50 PM
boykster's Avatar
Inday makes a 1x2 distro amp
http://www.inday.com/hdda2/hdda2.htm
I have their 1x4 amp and it works great.
boykster is offline
Reply Home A/V Distribution
