Trouble w/ my Psyclone PSC01 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-19-2007, 02:20 PM - Thread Starter
Munkee915's Avatar
I just got my psc01 switch the other day and i was stoked. I wanted to run my Xbox 1, 360, and Wii in HD to my TV that only has 2 component inputs (and 1 was being used by my sat receiver). I hooked it up, but i can only get display 1 to work. Whatever is hooked into display 1 will come through, but if i try to switch to display 2-4, the screen is black. I thought maybe the cables were bad, but i swapped my 360 and my wii onto input 1 and both worked, but can't get anything to work on the other displays. Any idea what might be going on? If anybody uses this switch?
Also, i think i've noticed that whatever is being put through input 1 seems to come through on the tv as regular 4:3 w/ screen stretch on the edges, instead of 16:9 like when it's hooked directly to the component inputs.
I appreciate any help.
Thnx
Munkee915 is offline
Reply Home A/V Distribution
