Directv D11 vs. D12 measurements? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-19-2007, 11:58 AM - Thread Starter
KE2D's Avatar
I've got a system with a rack mounted Directv D11-500 sat receiver which has gone bad. I have a D12 I can replace it with. Anyone know if the D12 is the same size width and height wise? I have a Mid-Atlantic rack shelf that I'd like to re-use without getting a new front panel for it.
Eric
b
KE2D is offline
post #2 of 3 Old 07-19-2007, 02:30 PM
justtaint's Avatar
If you have both the D11 and D12, can't you check for yourself? :P
According to Google they aren't the same size
D11 10.75 x 7.5 x 2.5
D12 12.3 x 10.2 x 2.04
Tom
justtaint is offline
post #3 of 3 Old 07-19-2007, 03:12 PM - Thread Starter
KE2D's Avatar
Well, let me re-phrase that - I have access to a D12, but don't actually have it in my hands. The PDF manuals from Directv's web site don't give any kind of measurements, or for that matter, specifications at all.
The measurements you pulled from Google - were they for the D11-500, or one of the other variants such as the -300?
I saw on solidsignal's website that they list the same size measuremens for the D11-500 and the D12, but I need to be sure. I figured one of the system integrators lurking here would know off the top of their head....
Worse case is I'll grab my tape measure and stop at a CC or Bestbuy and meaure one.
Eric
KE2D is offline
Reply Home A/V Distribution
