4X2 True Matrix HDMI 1.3a Powered Switch w/ Remote Controller - Page 17 - AVS Forum | Home Theater Discussions And Reviews
Old 01-11-2011, 04:33 PM
Lukedog17's Avatar
Originally Posted by bnieman View Post
It certainly would affect trying to run a 720p and 1080p display at the same time, the format would default to 720p on both displays. The same holds true with audio, if one output is a receiver that supports Dolby Digital 5.1 and the second device is a TV (stereo) the outputted audio will be stereo PCM and NOT a 5.1 bitstream since one of the output devices (in this case the TV) does not support receiving a 5.1 bitstream.
You can thank our friend HDCP for all these issues
I am not sure how I missed this post of your's. Seemed to answer my question before I asked it and I have read the whole thread too.
Oh well. Thanks for repeating yourself bnieman.
Lukedog17 is offline
Old 01-11-2011, 11:52 PM
dcmo's Avatar
Well I just got one of these thinking it could be the solution to a problem, but now I'm wondering if this is going to work or not.
First off; I'm running an HTPC with an extended display (there will be actually two output sources besides the standard monitor and didn't want to buy 360's all the way around). My video card only has one hdmi output so the need for this came up.
It's one thing that I have to shut the computer down before I can make my connection but this is something entirely else.
The main issue I have with this is my extended display isn't working properly. Both desktops show up (with icons on the main and just the background on the extended), but as soon as I open something up it automatically moves over to the extended display. I can't move the mouse back to the main monitor or drag a program or window back over to the main.
My main monitor has been set to be the main monitor, the output from the switch is going to a receiver.
Any ideas on why the switch is seizing control from the comuter?
dcmo is offline
Old 01-12-2011, 09:41 AM
bnieman's Avatar
I'm not sure I fully understand your question as it seems to have more to do with how your computer/graphics card handles multiple monitors.
Most video cards with 3 ouputs (for example 2 DVI ports and 1 HDMI port) can only have 2 of those outputs active at one time. So if you enable HDMI output it will disable one of your DVI outputs. This might explain your situation? Again I don't fully understand what the switch has to do with your issue.
As for opening windows, on my extended desktop a new window will open in the last place it was before the program closed. So if I had my web browser open on my secondary monitor when I closed it, the next time I open it will open on that same secondary monitor.
Hope this info helps, otherwise please try to further explain your issue.
Cheers
bnieman is offline
Old 01-12-2011, 09:47 AM
dcmo's Avatar
Well, I got it figured out and turned out to be a simple little thing. It turned out that the display is being picked up on the opposite side as before. Instead of dragging to the left while on the extended display, now you have to drag to the right. As far as a window automatically opening up on the extended display, it could be that it was shut down on it previously (although I'm pretty sure that I didn't shut down the screen resolution screen on it).
Also for me a fresh boot-up doesn't make a hand shake; I have to do a restart instead of a complete shut-down. Still a pain in the butt; I've got a Ceton and it takes a few minutes to get it going from a restart or a start-up from a shut-down.
Not having any audio problems so far as I can tell.
dcmo is offline
Old 01-14-2011, 10:27 AM
Lukedog17's Avatar
In regards to the "weakest link" in your HDMI chain; if your HDTV has a Dolby Digital Decoder will you not be able to get at least Dolby 5.1 out to your receiver hooked up to output B?
Will the decoder "decode" dts? Searched but can't find the correct answer.
Thanks for the help!
Luke
Old 01-14-2011, 10:38 AM
bnieman's Avatar
Luke
Most TVs decode both Dolby Digital and DTS (and all TVs with an ATSC tuner decode Dolby Digital) but they still tell the input HDMI device (via HDCP) that they are going to output stereo after decoding which will set your ouput B to stereo too even though it's a 5.1 capable receiver.
bnieman is offline
Old 01-14-2011, 11:02 AM
Lukedog17's Avatar
Thank you very much, i was afraid of that. You have been more than helpful to me. Stupid EDID.
Do you use a matrix at all or are you just knowledgible in the subject?
Old 01-14-2011, 11:15 AM
bnieman's Avatar
I own and use the Monoprice 4x2 Matrix everyday I learned the "least common denominator" rule the hard way though... I stay subscribed to the thread so I can hopefully save someone else the headache.
My solution was the route my audio completely seperate from my HDMI video. I have two 75 ft. optical cables and two 75 ft coax cables coming from my basement to my living room for digital audio... it was a pain running the extra cables but now I have zero issues with bitstreaming 5.1. Most of my devices have both optical and coax digital audio output so I use 1 for my basement preamp/processor and 1 for my receiver in my living room. My TiVo only has optical so I bought a really inexpensive optical audio splitter from Monoprice and it's worked flawlessly since day one. For the high-res formats like DTS-HD-MA and Dolby True I utilize the analog outputs on my Blu-Ray player for the basement. The living room is out of luck in that regard, but my receiver doesn't support them anyway so I would need to run analog regardless.
I can't imagine life without the 4x2 switch now though, all my components are in the basement and I have access to them all in my living room. Everything plays nice with my Harmony remote too.
The switch works as well as it's allowed to by the law of HDCP and EDID (which I would bet causes more headaches than saves content from being copied)
Cheers
bnieman is offline
Old 01-14-2011, 11:41 AM
Lukedog17's Avatar
If you have both A and B outputs set to the same input it will downgrade audio on both. If you are watching different sources then the HDCP handshake will only occur between the one input and one output selected.
HDCP
All-in-all though I've been very happy with my switch. My Logitech Harmony remote takes care of the switching so everything downstairs in my home theater is only a button press away from my living room.
b - what if you are playing 2 different sources; 1 to the theater and the other to an LCD? ie - Bluray to theater(thru receiver) and HDTV (straight)to LCD? I understand the 1 source on 2 displays but what about this case? What about when you are only playing bluray to the theater and the other display is not on? OR does it just not matter at all. Sorry for all the questions.
Luke
Old 01-14-2011, 12:12 PM
bnieman's Avatar
Luke
The switch lets you watch any input on any ouput. So you could watch Tivo on output A and BluRay on output B, or you could watch Bluray on output A and output B simultaneously.
The "least common denominator" rule comes into effect when you want to watch the same input on both output A and output B. The applies for both video and audio.
bnieman is offline
Old 01-15-2011, 07:14 AM
Lukedog17's Avatar
Thanks B. For 90% of the time I will be watching different source at the same time so maybe this will actually work for me. Even then, most of the time both displays won't be on at the same time.
Old 01-15-2011, 10:38 PM
bnieman's Avatar
The 5.1 audio down converting will still try your patience though. Even with my projector in standby mode (which is as off as it gets without cutting power to it) it still broadcast its EDID and if Output A and Output B were set to the same Input it would down convert the audio to stereo. So you have to make certain EVERY time you watch Output A that Output B is not set to the same input. Logistically it becomes extremely annoying.
bnieman is offline
Old 01-16-2011, 12:28 PM
Lukedog17's Avatar
Gotcha. I figure I wont be outputting the same source material to both displays or even have both displays running at the same time. So when I am watching a bluray through my receiver to my projector I will not be sending it to my LCD at the same time. I probably wont even have the LCD on for that matter. I will just have to make sure the source isn't being sent to the LCD even when it is off correct?
Old 01-16-2011, 08:53 PM
bnieman's Avatar
Correct, that's how it worked for me anyway. Best of luck and report back any new discoveries.
bnieman is offline
Old 01-17-2011, 08:17 AM
Lukedog17's Avatar
Thanks for all your help. I will report back but it will be a while since my room is still a work in progress. Running all the electrical and cables this week.
Old 01-17-2011, 06:20 PM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
I thought I'd ask in this thread rather than start up a new one, since "matrixing" or switching multiple inputs for two outputs is the topic at hand, and I'm considering this Monoprice 4x2 device as a solution to my challenge:
I currently have a HT with HDMI 1.3 BD player, 1.3 AVR, and 1.2 PJ (and other sources like DVR, DVD, all will be via HDMI). All sources currently switched by the AVR.
I'm considering getting a 3D PJ, 3D BD player, and getting some 3D via cable (On demand, ESPN3D).
I'd like to keep the current PJ for non-3D use - I won't be able to sell it for much, and I like the pic (it's a DLP).
I'm going to keep my current BD player too, since it is an Oppo 83, for SACD/DVD-A etc.
So, in order to watch 3D on the 3D PJ and 2D on the old PJ (not at the same time!), I would need to switch between the AVR HDMI output and the 3D BD player HDMI out, run it to the PJs 40' of cable away, and then split the signal to either PJ. Theoretically the split can occur before the 40' run, necessitating another 40' HDMI cable.
If I use two Monoprice unpowered switchers, one modified to be a "selector-splitter", I can achieve my goals. I could also use a 4x2 (or 2x2) matrix switch, provided I keep the sources different when watching 3D BD to avoid common-denominator EDID issues.
I have made the assumption (based on comments here and elsewhere) that my HDMI1.2 PJ (a BenQ W5000) will report an HDMI1.2 EDID even if in standby, and therefore a "normal" powered splitter is not appropriate, because the source will always see the BenQ.
Suggestions or comments on either approach, and my assumptions in getting there?
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
Old 02-15-2011, 03:30 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
I would fault your Projector then. Check with the manufacturer. I have a 2.5 year old Epson 1080UB and it does the correct thing. I can always get PCM 5.1 or Dolby Digital or any of the other codecs that my AVR supports even with the projector plugged in and turned on or off. Never had a problem. So, my projector must be doing something right then.
bommai is offline
Old 02-15-2011, 03:35 PM
bnieman's Avatar
That is very interesting because my projector is a Epson 1080UB Pro (essentially the same as yours)
bnieman is offline
Old 02-15-2011, 05:38 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
Hmm. I have the HDX-402E from Monoprice. Is yours the same? I use the PS3 (gen 1) as my bluray player. I am able to get Deep Color and 24Hz output on my projector. I am able to get PCM 5.1 as well as DD and DTS in the receiver. I have a HD-DVD player in another room and I could bring it to my main room to see if that works fine too or not. May be it is a combination of the projector and the player.
bommai is offline
Old 03-07-2011, 02:10 PM
StrapsTivis's Avatar
I have question on the Remote for this item. Has anyone tried to get the commands for the remote into the Harmony one?
StrapsTivis is offline
Old 03-07-2011, 02:16 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
The device is supported by the harmony database. Just choose av switch as device type monoprice as brand and the model number. It is listed. Mine works great.
bommai is offline
Old 04-01-2011, 01:36 PM
robmarch's Avatar
If both the projector and LG LCD TV are 1080p you will get 1080p video. You will only get stereo sound though on your Onkyo because your TV can only do stereo.
are there any tv's that won't reset the audio to stereo?
robmarch is offline
Old 04-01-2011, 02:19 PM
aggmiami's Avatar
Quoted: 32 Post(s)
I posed the below question in my own thread, but maybe someone using the 4x2 can make me feel better about what I am trying to accomplish. I am also interested in what people are using to control these with? Looking for an RF/Wifi type solution that I could also use for lighting control.
THANKS!
Need to distribute 4 sources to 4 different rooms (sources will be located in hallway closethome network is also in there)
Sources
- 2 U-verse receiver/DVR's
- 1 Panasonic BDT-110 Bluray player
- 1 ATV (2nd Gen)
(there is also a Yamaha HTR-5460 in this closetpossibly put my PS3 in there as well)
TV's
- 2 26 Insignia LCD's (1080p output)
- 1 46 Sharp Aquos LCD (1080i)
- 1 32 Olevia LCD (1080p)
planning on using Monoprice 4x4 Matrix/Switcher (product #5704 , http://www.monoprice.com/products/pr...seq=1&format=2 ). I believe the longest HDMI run will be no more than 50' from the closet. It seems pretty straight forward, correct?
2-Channel: aTV>FiiO D3>Rega Elex-R>PMC 20.22's
Other Gear: Denon avr-1910, DefTech PM1000's, PC2000, UIW B/PA's, Emotiva Ultra-12, ATH-M50X
Member: E.S.A.C. (Eastern Shore Audio Collective)
aggmiami is offline
Old 04-07-2011, 08:00 AM
aggmiami's Avatar
Quoted: 32 Post(s)
THANKS!
Sources
- 1 ATV (2nd Gen)
TV's
Bump...Monoprice users please comment.
aggmiami is offline
Old 05-01-2011, 03:44 PM
12voltguys's Avatar
THANKS!
Sources
- 1 ATV (2nd Gen)
TV's
Yes, looks pretty straightforward. It should work fine.
12voltguys is offline
Old 05-03-2011, 06:35 PM
aggmiami's Avatar
Quoted: 32 Post(s)
Thank you
aggmiami is offline
Old 04-11-2014, 04:57 PM
BakeApples's Avatar
Quoted: 245 Post(s)
Liked: 139
I`m looking for a 4x2 HDMI matrix and found a model from Wentronic called "AVS45" and was wondering if anyone here have any experience with this matrix? Couldn`t find any reviews after a quick google search so i`m hoping someone here maybe uses this. It also goes under the name "Goobay" HDMI matrix/switcher on other sites selling it.
https://www.wentronic.com/de-en/index/artikel/transmit-up-to-4-HDMI-signals-to-2-LCD-Plasma-TV-s-60817
Sony VPL-VW550 | DNP Supernova 08-85 116" 2.35:1 | Lumagen Radiance Pro 4440 | Pioneer SC-LX89 | Oppo UDP-203 | Zappiti One 4k HDR | PS4 | Audio Pro/Pioneer 5.1.4 Atmos | SVS SB-1000
BakeApples is offline
Old 04-11-2014, 05:24 PM
BakeApples's Avatar
Quoted: 245 Post(s)
Liked: 139
Is it possible to also choose which output to use on the matrix in the Harmony software? For example, can i create two different activities in the harmony software, one for TV and the other for Projector and choose an output for each and then switch between them without having to use the Monoprice remote?
Old 04-11-2014, 09:30 PM
Roomraider's Avatar
The answer is absolutely.
Roomraider is offline
Old 04-12-2014, 07:26 AM
BakeApples's Avatar
Quoted: 245 Post(s)
Liked: 139
I just made an order for a Monoprice HDX-402E, looking forward to try it out.
