Official RadianceXD support thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #631 of 1503 Old 04-12-2011, 11:24 AM
12GAGE's Avatar
Quoted: 53 Post(s)
Liked: 47
I would definitely second that request from Fudoh. I am in a similar situation where I have another unit in line after the Radiance. It would be great to have a working passthrough so that I can make sure this second unit can accept and process the 3D signal from the Radiance before purchasing the full 3D upgrade Radiance upgrade. Thanks in advance.
12GAGE is offline
post #632 of 1503 Old 04-12-2011, 11:48 PM
jrp
jrp's Avatar
Quoted: 230 Post(s)
Liked: 476
Originally Posted by Fudoh View Post
Feature Request
Jim, would you consider "unlocking" 3D passthrough for Radiance units without the actual 3D upgrade ? ...
Sorry, no.
Jim Peterson
Lumagen
jrp is offline
post #633 of 1503 Old 04-13-2011, 08:14 AM
12GAGE's Avatar
Quoted: 53 Post(s)
Liked: 47
I was wondering if 2 Radiance units would be need for a dual projector passive 3D setup ? (Or could you specify left/right output within the current output of a single unit) I have been hearing that updated software was released but had not heard any specifics. Thanks.
12GAGE is offline
post #634 of 1503 Old 04-13-2011, 10:07 AM
patrick harkin's Avatar
Yes, it takes 2 Radiance units (they could both be Mini's) to drive a dual input separate left/right eye 3D system.
Patrick Harkin, Lumagen Inc. engineer
patrick harkin is offline
post #635 of 1503 Old 04-26-2011, 02:59 PM
bgosselin's Avatar
I have a question for the XD owners. I have a Statement D2 pre-amp. My Pre-amp is getting older and the upgrade path with Anthem is very steep. My pre-amp can't handle the new audio codec. For this reason I feed it a PCM signal coming from my PS3. I just purchased a RS40 and trying to find a way to get my setup as easy as possible. One thing I was thinking of doing was to buy a used XD and do the firmware upgrade to get acces to calibration of 3D source. I was thinking of getting all my sources hook to the XD and get an HDMI out of the XD to my Anthem to get the sound treatment. Can I send PCM to the XD and get it out after to my Anthem? I've been told that the XD can't handle uncompressed audio.
bgosselin is offline
post #636 of 1503 Old 04-26-2011, 03:15 PM
sfogg's Avatar
"Can I send PCM to the XD and get it out after to my Anthem? I've been told that the XD can't handle uncompressed audio."
That isn't correct, it handles LPCM just fine. You would use the first output to feed 3D video to your projector and the second output to output a blank video signal along with the audio to your Anthem.
What the XD can't do is handle the lossless formats while they are still bitstream. If the PS3 decodes to LPCM the Radiance will handle that just fine.
Shawn
sfogg is offline
post #637 of 1503 Old 04-26-2011, 03:44 PM
bgosselin's Avatar
So I am not missing much by going with an XD instead of the XE. So far every players that plays advanced codecs can decode them and output lpcm right?
Bruno
post #638 of 1503 Old 04-26-2011, 05:01 PM
amt
amt's Avatar
for the most part all blu-ray players can do lpcm. I have seen some set-top boxes that can not take the bistream audio and send out lpcm. As long as you stay away from those, you should be fine.
amt is offline
post #639 of 1503 Old 05-01-2011, 10:42 PM
Wizziwig's Avatar
Quoted: 1351 Post(s)
Liked: 952
Can the Radiance convert broadcast 720p60 film sources (like any TV series running on ABC or FOX) and output 1080p24? I know it does this for interlaced sources like 480i or 1080i but it's unclear from the specs if it detects film cadence in progressive sources and convert them to 24p.
Wizziwig is offline
post #640 of 1503 Old 05-02-2011, 03:58 AM
alex_t's Avatar
Quoted: 45 Post(s)
Liked: 81
Hello.
Yes it can do p@60 to 1080p@24. Test done with a Radiance XD.
Regards
alex_t is offline
post #641 of 1503 Old 05-13-2011, 07:48 PM
rachmat-d's Avatar
Quoted: 34 Post(s)
Jim,
It is possible to upgrade radiance XD to 3d , without sent the unit to you ?
Because no distributor in here.
rachmat-d is offline
post #642 of 1503 Old 05-14-2011, 12:10 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Yes, you simply purchase a key to unlock the 3D features already available in the firmware.
Fudoh is offline
post #643 of 1503 Old 05-14-2011, 01:49 AM
rachmat-d's Avatar
Quoted: 34 Post(s)
How about HDMI ?
Do i need to upgrade to 1,4 ?
post #644 of 1503 Old 05-14-2011, 02:12 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
As far as I know, the XD (with HDMI 1.1) also fully supports 3D Video, so there's no need for upgrading the HDMI ports.
There's a tidbit about possible issues when routing audio through the Radiance at the same time as processing 3D.
From Lumagen's website: The XD has an issue with some 3D output formats when audio is also output to the display that can cause video to be intermittently blacked out. Can be worked around now if you configure the XD to drive audio on the other output and turn audio off on the 3D video output.
Fudoh is offline
post #645 of 1503 Old 05-14-2011, 03:12 AM
rachmat-d's Avatar
Quoted: 34 Post(s)
Thanks Fudoh.
post #646 of 1503 Old 05-17-2011, 09:08 PM
rachmat-d's Avatar
Quoted: 34 Post(s)
Is there a instruction to calibrate with 3D ?
Is it the same with normal one or different Test pattern ?
post #647 of 1503 Old 05-18-2011, 10:29 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
Some TVs can be forced into 3D mode. With those, you don't need a 3D pattern source... your 2D test patterns will be converted to 3D by the TV. But many TVs will only switch to 3D mode if they are sent a 3D source so you'd have to have either a 3D-compatible video signal generator or a 3D Blu-ray disc with 3D patterns on it. I don't know of a 3D Blu-ray disc with calibration patterns... yet. The AV Foundry Video Forge signal generator can convert any pattern to 3D and also offers some extra-cost 3D patterns that are 3D only.
Once you have the 3D source for calibration patterns, you have to have a meter that allows you to put the 3D glasses over the lens of the meter and the glasses have to be turned on. 3D makes the light seen through the 3D glasses very dim so the meter will struggle to make readings if the meter isn't very very good at measuring low light levels (not many meters are, even the ones selling for 5 figures).
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #648 of 1503 Old 05-18-2011, 12:22 PM
Josh Z's Avatar
Quoted: 2420 Post(s)
Liked: 1589
Just one point of clarification: Unless the TV specifically has 2D-to-3D conversion, you may be able to force a 3D mode such as top/bottom or side-by-side with 2D content, but the image will be badly distorted. Even so, some test patterns may still be usuable.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #649 of 1503 Old 05-18-2011, 06:38 PM
rachmat-d's Avatar
Quoted: 34 Post(s)
Thanks, Dough and Josh.
post #650 of 1503 Old 06-18-2011, 12:38 PM
Mike_WI's Avatar
Quoted: 212 Post(s)
Liked: 143
FW Updates for Production 061011:
XD/XD3D
XE/XE+/XE3D
XS/XS+/XS3D
Production 061011
Big improvement to the user interface of the output setup command.
It's much more powerful and is now located under the Output menu----so no need to go wading thru the input menu to set up the output settings anymore (although we've kept the output setup command in the input menu for anyone who's used to finding it there.)
With this new command you can do things, for instance, like quickly check what all the inputs are using for CMS or if you want to set memory A of all inputs to use Style3 and leave the other output settings untouched you can do that easily.
We've updated the tables of 8 output modes/CMS's/Styles now to display checkmarks next to setups that are being used.
Also several bugfixes.
I haven't FW updated in a while -- or checked in on the forum.
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #651 of 1503 Old 06-24-2011, 09:06 AM
Mike_WI's Avatar
Quoted: 212 Post(s)
Liked: 143
FW Updates for Production 061611:
XD/XD3D
XE/XE+/XE3D
XS/XS+/XS3D
Production 061611
- Fix for frame-dropping bug in 060211-061011 firmware.
Couple other minor improvements.
Updated Documentation (see above links for links)
Updated XD/XE manual
Updated Tech Tip 11 (RS232 control)
New Tech Tip 12 (IR interface)
HT Details: link
Mike_WI is offline
post #652 of 1503 Old 06-28-2011, 10:57 PM
jrp
jrp's Avatar
Quoted: 230 Post(s)
Liked: 476
For now, select and display a 3D source on your TV/projector. Then select a Radiance internal test pattern as normal. The pattern will be output in "3D" ... but it still looks 2D.
Later we will be adding a way to select 3D pattern wothout requiring an active 3D source.
Jim Peterson
Lumagen
jrp is offline
post #653 of 1503 Old 06-30-2011, 09:31 AM
Quoted: 188 Post(s)
Liked: 353
You also need to mount the 3D glasses so that 1 lens of the glasses is covering the lens of the meter (this assumes you are measuring light reflected from the screen if using a front-projector). And the 3D glasses must be turned on if they have a power switch. Many calibration meters won't be able to read below 30% white or so because so much light is lost in the process of creating 3D images. 50% is lost just from using alternating eyes, more is lost because the glasses have their own light-blocking density that can't be changed or eliminated. It's common to see 15 fL for 100% white on a 2D front projection system to drop below 3 fL for 100% white in 3D. Flat panels set to 30-35 fL for 100% white in 2D are likely to make 6-7 fL for 100% white in 3D. By the time you get down to 30% white in 3D, there's not a lot of light left to measure.
THX -- ISF -- HAA
post #654 of 1503 Old 06-30-2011, 01:48 PM
Mike_WI's Avatar
Quoted: 212 Post(s)
Liked: 143
FW Updates for Production 062511:
XD/XD3D
XE/XE+/XE3D
XS/XS+/XS3D
Production 062511
Bugfix for increased video judder occurring in 0602-061611 revisions with 24Hz in and 24Hz output rate.
Added ability to genlock 24Hz sources to 96/120 Hz output modes.
Couple other small bugfixes and improvements.
Updated Documentation-
New Tech Tip 13 (Direct commands and menu shortcuts)
HT Details: link
Mike_WI is offline
post #655 of 1503 Old 07-02-2011, 07:38 AM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 43
Question for Jim:
I picked-up a Sencore branded XD recently (NOS) and to change gamma settings it tells me I need to enter the service code; where do I find that? Or, can you send it to me please?
Dan
(used the forum since it's the holiday weekend)
Dan Francis
DanFrancis is offline
post #656 of 1503 Old 07-02-2011, 08:47 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Service Mode allows for some more advanced settings than the standard user mode. You can change the menu mode here: Main Menu > Other > Menu Control > Menu Mode.
Fudoh is offline
post #657 of 1503 Old 07-02-2011, 03:26 PM
DanFrancis's Avatar
Quoted: 44 Post(s)
Liked: 43
Thank you!!
Dan
Dan Francis
post #658 of 1503 Old 07-06-2011, 06:07 AM
Mike_WI's Avatar
Quoted: 212 Post(s)
Liked: 143
FW Updates for Production 062611:
XD/XD3D
XE/XE+/XE3D
XS/XS+/XS3D
Production 062611
Fix for stutter/judder issue sometimes affecting video when genlocked and input/output refresh rates are the same, most noticeably 24Hz sources with 24Hz output mode.
Added 720p96Hz to output mode list.
HT Details: link
Mike_WI is offline
post #659 of 1503 Old 07-13-2011, 06:56 AM
Mike_WI's Avatar
Quoted: 212 Post(s)
Liked: 143
FW Updates for Production 062711:
XD/XD3D
XE/XE+/XE3D
XS/XS+/XS3D
Production 062711
Small improvement to genlocking source to output if both are running at 59.94Hz.
HT Details: link
Mike_WI is offline
post #660 of 1503 Old 07-21-2011, 05:14 PM
Mike_WI's Avatar
Quoted: 212 Post(s)
Liked: 143
Production 070111 FW Updates:
XD/XD3D
XE/XE+/XE3D
XS/XS+/XS3D
Production 070111:
Adds ability to genlock sources running at 24/60Hz to 96,120Hz output refresh rates
(although genlocking to 96Hz output is only appropriate for 60Hz input rate when the input is interlaced and a film source).
HT Details: link
Mike_WI is offline
Reply Video Processors
