Official RadianceXD support thread - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1351 of 1490 Old 06-05-2014, 10:28 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
Lumagen recommends backing up your settings to a PC, doing a factory reset on the Radiance processor, then download your settings from the PC to the Radiance again to restore them. They recommend this for each firmware update, though I admit to not doing it every time myself. But if I have some previously not-seen problem, I will do it to see if the problem goes away... occasionally, it does stop some oddball things, other times, there's no change. Not saying that's your issue, but it might be.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #1352 of 1490 Old 06-05-2014, 11:16 PM
p5browne's Avatar
Quoted: 2794 Post(s)
Liked: 2113
New Calman Version 5.3.5 RC3 Build #1578
http://color.spectracal.com/downloads/
Fixed Issues
June 5, 2014
Further refined the Pattern Delay Optimization. This should help improve the results by removing luminance from the calculations.
Resolved an issue with the i1Pro and i1Pro 2 that would cause CalMAN to be unable to communicate with the meter if CalMAN attempted to connect to it a second time
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #1353 of 1490 Old 06-06-2014, 03:23 PM
AnotherDude's Avatar
Quoted: 18 Post(s)
Liked: 36
Thanks, Doug, I'll give that a try.
Sharp Elite PRO70X5FD
Lumagen Radiance 2143
OPPO BDP-105D
AnotherDude is online now
post #1354 of 1490 Old 06-07-2014, 06:31 PM
Quoted: 18 Post(s)
Liked: 36
Well, still no joy. I reverted to 011814. This got rid of the weird behavior. I then saved my settings with the config utility (1.6), updated to 050314, restored the settings, and same thing.
Sometimes when switching format or input (probably because that switches the format) I first get a small 1/4 size image at the upper left corner, then a 2-3-second blackout then the full image. I'm trying to post on the Lumagen forum but the admin must be on vacation to approve my registration from four days ago ...
I've reverted to 011814. And oh dang, I just checked and there's a new 1.7 utility. I'll give that a try. Sigh.
OPPO BDP-105D
post #1355 of 1490 Old 06-07-2014, 07:01 PM
Quoted: 18 Post(s)
Liked: 36
Oh well, same thing. Must be a new "feature" to make you think about upgrading to one of the new 20xx models smile.gif.
One thing I noticed is when updating to the latest two new versions, it skips sections 2 and 1 and only updates section 0, whereas the 011814 update does all three sections. Hmmm ...
OPPO BDP-105D
post #1356 of 1490 Old 06-07-2014, 07:23 PM
p5browne's Avatar
Liked: 2113
From a discussion that came up in the Calman Forum - the New 21XX series doesn't take a 4K Input?
OK, I get it - 2XXX, means 2D input.
post #1357 of 1490 Old 06-08-2014, 02:32 AM
Gordon Fraser's Avatar
Quoted: 114 Post(s)
Liked: 149
If you want to fore all three sections then use the bootloader update method...
prepare the firmware for uploading then pull power lead from video processor, then within 5 seconds of re-attaching power cable press SEND on upload...the scaler will stay off but will now update all sections. you will not lose any settings.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #1358 of 1490 Old 06-08-2014, 09:23 AM
Quoted: 18 Post(s)
Liked: 36
Thanks, Gordon. Would that be any different from backing up the settings with the utility before the regular update then restoring them afterwards?
OPPO BDP-105D
post #1359 of 1490 Old 06-08-2014, 10:32 AM
alex_t's Avatar
Quoted: 28 Post(s)
Liked: 57
Hello,
You can also tick FORCE UPDATE. This is a regular update which allows to overwrite all of the sections.
alex_t is online now
post #1360 of 1490 Old 06-08-2014, 11:34 AM
Quoted: 18 Post(s)
Liked: 36
Originally Posted by alex_t View Post
Hello,
Thanks Alex - I'm Spanish, no worries smile.gif.
OPPO BDP-105D
post #1361 of 1490 Old 06-13-2014, 12:41 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
Doug:
A slight correction. Generally we say you do not need to download your configuration to a PC, update Radiance software, and then upload the configuration back to the Radiance, with each update. This is not necessary since the configuration is preserved when doing an update. Even when we change the configuration data structure for an update, we put software into the update to translate an old configuration data structure to the new data structure automatically in the update (this is a very rare event).
As you note we have seen a couple cases where downloading and then uploading a configuration can recover if there is some corruption in the Radiance internal Flash memory that stores the configuration. However, this is a rare exception.
Downloading your configuration is recommended as a backup in case of any bad things happening to your Radiance.
Jim Peterson
Lumagen
jrp is offline
post #1362 of 1490 Old 06-13-2014, 01:38 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
A couple comments on updating, the force option and boot mode.
There are three code sections, and the updater looks to see which ones are not current and need to be updated. Unless there is some issue you believe is a bad Flash memory bit, there is no need to select the "Force" option. The FPGA section takes the longest (currently about 15 minuted in the 2XXX units) and so if it has not changed since your last update you would save a lot of time by leaving the force option off.
If you believe you Radiance is behaving strangely, then a force update might help in the remote case of a Flash ROM bit flipping. Since the Flash stores the data as a charge on the input of a transistor, it is possible for the charge to be disturbed changing the Flash bit value. A bad Flash ROM code or data bit can cause strange behavior (e.g. changing inputs randomly, etc.) or even cause your Radiance to lock up. So, having a Flash ROM bit flip is possible, and doing a "Force" update can recover the Radiance back to proper operation.
Doing a "Boot Mode Update" is only recommended for a unit that does not turn on at all. If you turn the Radiance on with the remote and get a "green LED on" indication on the front panel, you can most likely do a normal update with the "Force" option selected.
Jim Peterson
Lumagen
jrp is offline
post #1363 of 1490 Old 06-13-2014, 04:21 PM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
I have an XS-3D. I was looking in the manual at the procedures to deal with overscan and I generally found it confusing. It seemed there was a warning not to use it on 1080i. My input is 1080i 60 and 1080P 60 is the output. I need to reduce the screen size as I don't want any overscan? This was amazingly simple on a DUO. The source is PC and I can send 1080P 60 to the Lumagen but since the Lumagen won't redinterlace 1080P, I felt 1080i 60 would be an effective work around. The PC is using intel integrated graphics and doesn't want to scale interlace output.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #1364 of 1490 Old 06-13-2014, 05:09 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
What display are you using? Can the overscan be fixed there? Most modern panels have a mode with 1:1 pixel mapping, no overscan. That's better than scaling down.
(I also don't understand what interlacing/reinterlacing has to do with overscan?)
ScottJ is offline
post #1365 of 1490 Old 06-14-2014, 12:11 AM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
The "Output Shrink" command is used to reduce overscan. You just need to increase the left, top, right, and bottom, values to reduce image size on each edge as needed. The command is: MENU . Output . Styles . [Styles] . Mask/Shrink . Shrink
There is no limitation on the input or output format when using the output shrink command. Feel free to send 1080i (or any supported format) to the Radiance when reducing overscan.
I would be interested in what you read that made you worry about 1080i input. If you could post the text in question (or email it to support@lumagen.com) it would be helpful.
Jim Peterson
Lumagen
jrp is offline
post #1366 of 1490 Old 06-19-2014, 09:21 AM
Quoted: 18 Post(s)
Liked: 36
Almost three weeks ago I registered on the Lumagen forum, and I'm still waiting to be confirmed. I sent the admin two e-mails wondering what the problem was, but no answer. Is this normal? Are they on holiday or something? Or do they not like me?
OPPO BDP-105D
post #1367 of 1490 Old 06-19-2014, 11:29 PM
p5browne's Avatar
Liked: 2113
Firmware Updates All Models
http://www.lumagen.com/testindex.php?module=updates
Improved Colour Patterns, resulting in Deeper, and Bolder Colours
post #1368 of 1490 Old 06-19-2014, 11:51 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Where did you get that idea from?
The actual changelog:
"Precision improvements were made for color accuracy including test patterns."
More discussion
ScottJ is offline
post #1369 of 1490 Old 06-20-2014, 08:22 AM
p5browne's Avatar
Liked: 2113
More discussion
Eyeballing after a DDC Reset - will check my results tonight from last night's calibration. Darn issues with 100% Blue rising after the 125 Point 3D LUT calibration. Being it was 3AM when finished, will leave and check tonight as well.
post #1370 of 1490 Old 06-20-2014, 05:06 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
Send an email to support@lumagen.com with your desired login name and we will try to get you set up with the Lumagen forum.
AnotherDude likes this.
Jim Peterson
Lumagen
jrp is offline
post #1371 of 1490 Old 06-20-2014, 05:13 PM
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
For now we are using the naming convention that the 1000's digit is the input rate (i.e. 2XXX units have 2k input rates), and the 10's digit is the output rate. The 100's digit is the generation, and the ones digit is a specific product within that generation.
So Radiance 214X units have 2k input and 4k output.
Jim Peterson
Lumagen
jrp is offline
post #1372 of 1490 Old 06-20-2014, 05:23 PM
Quoted: 18 Post(s)
Liked: 36
Thanks, jrp - message sent!
OPPO BDP-105D
post #1373 of 1490 Old 06-23-2014, 10:27 PM
p5browne's Avatar
Liked: 2113
http://www.lumagen.com/testindex.php...ancexe_updates
Production 060914- Fixes up a few bugs in some of the test patterns in the previous release. (061014 for 20XX and 21XX)
post #1374 of 1490 Old 06-29-2014, 07:28 PM
Rcap's Avatar
XD Video Tearing
Ever since updating to 050314 (from 061413) I've been getting this tearing issue on the top of the screen on some commercials. Never seems to occur during regular program material. (Mostly we've been watching the World Cup.) I'm now updated to 060914 with the same issue. Any thoughts out there in the Lumagen world?
Rcap is offline
post #1375 of 1490 Old 06-29-2014, 08:01 PM
thrang's Avatar
Quoted: 1604 Post(s)
Liked: 1377
Originally Posted by Rcap View Post
Ever since updating to 05314 (from 061413) I've been getting this tearing issue on the top of the screen on some commercials. Never seems to occur during regular program material. (Mostly we've been watching the World Cup.) I'm now updated to 060914 with the same issue. Any thoughts out there in the Lumagen world?
I think whatever match your watching, its likely an exciting nil-nil score...
Sorry, I've not seen that artifact with any firmware. Have you unplugged from power for 30 seconds, and re-powered it? I've seen other odd issues with Lumagen's over time that a hard power cycle seems to clear.
thrang is offline
post #1376 of 1490 Old 06-29-2014, 08:14 PM
Rcap's Avatar
Thanks. Yes, tried that. The only thing I haven't tried yet is a reset to factory defaults. May be in my future...
Rcap is offline
post #1377 of 1490 Old 06-30-2014, 06:25 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
Another thing you might try is to switch to a channel with a different resolution (e.g. 480i) and then switch back again.
dsinger is offline
post #1378 of 1490 Old 06-30-2014, 10:27 AM
Quoted: 18 Post(s)
Liked: 36
Two things I've been observing with the latest is occasionally when switching inputs it goes black, switching back and forth recovers it. And other times I'll get a temporary small picture in the upper left apparently when switching formats before the full image shows. This last one only goes away if I revert to 011814, not later.
For now I'm living with it :-)
OPPO BDP-105D
post #1379 of 1490 Old 06-30-2014, 11:03 AM
Quoted: 188 Post(s)
Liked: 352
The first thing I would do is revert to the 2013 firmware to see if, indeed, the problem is absolutely related to firmware version. Could be something coincidental happened when you updated the firmware.
Also, you can try backing-up your settings to a PC, do a full factory reset, then reinstall your settings from the PC.
When the commercial is screwed up, what happens when you select the Radiance menu or Info button so you display something the Radiance is generating at the same time you are experiencing the bad video from the commercial? If the Radiance menu or info screen is also screwed up, your video display is the source of the issue. If the Radiance menu or Info page are normal while the commercial is screwed up, the problem is in the Radiance or the source. This could help with troubleshooting.
THX -- ISF -- HAA
post #1380 of 1490 Old 06-30-2014, 11:41 AM
Rcap's Avatar
Good points. I'll check next time I see the symptoms.
Rcap is offline
Reply Video Processors
