Official RadianceXD support thread - Page 48 - AVS | Home Theater Discussions And Reviews
 6Likes
post #1411 of 1429 Old 01-10-2015, 12:32 PM
p5browne's Avatar
Quoted: 429 Post(s)
Liked: 296
After all these years!
Getting an issue while manually calibrating the Samsung UN65HU9000 Greyscale and CMS
(and previously the LG 55LHX, and the Samsung PN64F8500), I got that `Does not
Respond to setting changes' moments!
Will shut everything down, and start over, to continue to finish, or sometimes come
up with the same stalemate. But results were always mixed.
Also over the years was the Info screen popping up from the Radiances due to some
conflict with the TV Remote.
Pushing the Exit button got rid of that issue.
Last night, it finally dawned on me. The Radiance was also being affected in other ways
by the TV Remote, but because nothing was seen on screen, never thought my calibration
was being compromised!
So, last night I covered the front of the Radiance to prevent stray TV Remote signals.
Absolutely the BEST calibration I've done in years!
No more cursing the TV, Calman, and what ever! Radiance front stays covered through out
the calibrations from now on. Only signals going to it is the Serial Connection.
Addendum:
Turn Off the Radiance IR: MENU 0995. To turn back on repeat, or remove power Input, wait 10 seconds and reinsert.
p5browne is offline
post #1412 of 1429 Old 01-28-2015, 07:07 PM
Melgon's Avatar
Selling my Radiance XD
If anyone is interested, I just listed my Radiance XD on Ebay.
I hope posting this on AVS is not against the forum rules.
Thank you guys!
Name:	My Radiance XD.JPG
Melgon is offline
post #1413 of 1429 Old 01-31-2015, 10:07 PM
p5browne's Avatar
Quoted: 429 Post(s)
Liked: 296
Lumagen Radiance FW Updates
http://www.lumagen.com/testindex.php?module=updates
21XX:
Production 012515- Fix for an issue with factory reset after enabling 17x17x17 CMS that would give incorrect colors. Adds composite input option to 2124/2144 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2124/2144). Fix for composite input with film mode selected. Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits.
Update time ~15 minutes @57k from previous firmware
20XX:
Production 012515- Adds composite input option to 2022/2042 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2022/2042). Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits.
XE:
Production 012515- Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits.
Update time ~3minutes @57k from previous firmware
XS:
Mini:
XD:
p5browne is offline
post #1414 of 1429 Old 02-11-2015, 04:38 AM
Naiera's Avatar
Quoted: 13 Post(s)
Does anyone know if, ever, my RadianceXD will be able to pass a signal with proper chroma upsampling?
Naiera is offline
post #1415 of 1429 Old 02-11-2015, 05:55 AM
jrp
jrp's Avatar
Quoted: 51 Post(s)
Liked: 57
Naiera:
The Radiance does do proper Chroma upsampling. If you are referring to some test patterns that use out-of-band Chroma, as discussed else where, these patterns create situations that do not reflect real video when being processed/scaled. The patterns can be useful but you need to be aware of this.
The GF9450 deinterlacer has a very slight loss of Chroma bandwidth, but this should not be visible on actual video.
Naiera likes this.
Jim Peterson
Lumagen
jrp is offline
post #1416 of 1429 Old 02-11-2015, 06:02 AM
Naiera's Avatar
Quoted: 13 Post(s)
I'm referring to test patterns on the Spears & Munsil test Blu-ray. I've tried on both my Oppo BDP-103 and the old 83, before I sold it.
Naiera is offline
post #1417 of 1429 Old 02-11-2015, 12:18 PM
jrp
jrp's Avatar
Quoted: 51 Post(s)
Liked: 57
That is what I expected. These patterns are useful, but they create out-of-range values when converted to RGB, which are clamped (which cause changes in the waveform when processed), and since they are hard edge toggles (i.e. max-min-max-min) a Chroma filter will not work correctly since this is effectively "out-of-band."
No real video source would create either out-of-range RGB or out-of-band Chroma signals when properly processed and so the test pattern is not good to judge electronics that are processing the image. They are fine for seeing how you TV reacts to such a signal, but you need to understand the above discussion to make any judgments.
Don (Munsil) and I discussed the pro's and con's of this in a different thread (or maybe earlier in this thread. I don't recall exactly where).
At Lumagen, we did take the time to change the Radiance FPGA design to make this pattern look as good as possible, but found that the GF9450 chip did not pass it perfectly and there was nothing we could do to get the GF9450 to look better for this test pattern. BTW: You can bypass the GF9450 in the Radiance for progressive sources by selecting "Game Mode." This will improve this test pattern.
In my considered opinion, you are better off using a quality Blueray movie to judge Chroma bandwidth for real sources.
Naiera and Mike_WI like this.
Jim Peterson
Lumagen
jrp is offline
post #1418 of 1429 Old 02-18-2015, 07:31 PM
Naiera's Avatar
Quoted: 13 Post(s)
Is there a specific movie and scene you can recommend? I'm not very experienced with this, so I think you'll have to explain to me exactly what I'm looking for.
Naiera is offline
post #1419 of 1429 Old 02-18-2015, 09:23 PM
jrp
jrp's Avatar
Quoted: 51 Post(s)
Liked: 57
Naiera:
Good question. Unfortunately I don't have a specific recommendation to give you.
You might look for a a scene with cloth that has saturated colors in a pattern that creates high frequency changes in color as opposed to only Luma.
Evaluation of actual video is much more difficult then using a test pattern. The biggest issue is knowing how much detail is actually contained in the source and how close to ideal the display is reproducing the material. Also, there tends to be high frequency Luma changes where there is high-frequency Chroma. This actually helps the image as the high frequency Luma compensates to some degree for having less resolution in Chroma.
Chroma is compressed a lot more than Luma in real material. First there is the fact that consumer video is encoded as 4:2:0 (i.e. 1/4 resolution for Chroma), and the "DCT truncation matrix" and other compression algorithms are much more aggressive at throwing out high-frequency Chroma than they are high-frequency Luma. All this complicates the task of evaluating Chroma further.
Test patterns exploit some special encoding that would not happen in real material and so they can have higher frequencies than is normal in encoded video. This makes them useful especially if they follow the Nyquist sampling rules used for video. On-off patterns can be useful as well, if evaluated knowing how they affect video filters.
alex_t and Naiera like this.
Jim Peterson
Lumagen
jrp is offline
post #1420 of 1429 Old 03-28-2015, 02:31 PM
NxNW's Avatar
I have an interesting new bug: my Radiance XD can no longer pass through 1080p24 coming from my TiVo.
The issue surely arose as a result of a TiVo update, since my TiVo applies these automatically. My Radiance has not been updated for a couple years at least.
I know, the first resort for any problem is flash the latest firmware. And I might, but I sometimes hesitate do this when a) it has been a long time b) there is no way to roll back and c) there may be a simpler fix.
I have reviewed the last couple pages of this thread and did not see anything like this mentioned. So I'm asking now.
The issue happens when I am viewing VOD through the TiVo, either Amazon or Netflix (I haven't tested Xfinity yet) and the provider is streaming 1080p24.
I have my TiVo set to put out 1080p24 "pass-thru" if that's what *it* is receiving from upstream. This works when the TiVo is plugged straight into my TV, but not if the Radiance is in the chain.
I had the Radiance set to put *out* 1080p24 when it *received* 1080p24 on this input. It used to work, and this continues to work on other inputs such as the one for my Blu Ray player. But with the TiVo now I only get a picture if I set the Radiance to put out something else such as 1080p60.
It's more than just the picture: The TiVo even pauses playback when this problem occurs. Therefore I suspect TiVo has begun doing something new involving HDCP at the request of content providers. Playback works fine and I can see it if the TiVo and the Radiance can agree on something, I just don't know what.
I know, TiVo issue, but I thought I'd bring it up here since of course I will never get a knowledgeable response from a TiVo expert on something involving a Radiance whereas I might get the converse. Thanks in advance for supplying any interesting info you may have.
NxNW is offline
post #1421 of 1429 Old 03-28-2015, 05:29 PM
jrp
jrp's Avatar
Quoted: 51 Post(s)
Liked: 57
NxNW:
We have not other reports of such an issue, and I think others would have reported it if they also had an issues with a TiVo. So it may be confined to your system.
When this occurs, pess OK to see the Status. See if HDCP is on for the input and off for the output. If a Blueray player (and/or other HDCP source) still work this is not likely to be it, but it is worth checking.
You say this happens with 1080p24, but does the image pass properly if you have the TiVo set to a different output resolution with the same VOD material? Have you tried setting the TiVo to output 1080i for these sources? If it is just that you can't get 1080p24, it would not be an HDCP issue. Instead it would more likely be an EDID issue.
You can try disconnecting and reconnecting power to all your equipment, including the Radiance, to see if there is something temporary that this might help.
It might be a coincidence and just unplugging and re-seating the HDMI cables a few times between the TiVO and Radiance may help, or even trying a different HDMI cable.
It could even be that the Radiance has developed a hardware issue.
I think updating software in the Radiance is a good idea, and you can regress software. Look to see which software release you have now (press OK to bring up the Status screen) and download (and save to a file) your current configuration using our config reader utility. Then if you want go back to the software you have now you can download the release you over wrote and load it again. You should not need to upload the config you downloaded before updating, but you would have it if you notice anything that might be configuration related.
Jim Peterson
Lumagen
jrp is offline
post #1422 of 1429 Old 03-29-2015, 12:05 PM
NxNW's Avatar
This is very helpful, thank you for your prompt and knowledgeable assistance. I'll work on these suggestions and post my findings here later on. Cheers!
NxNW is offline
post #1423 of 1429 Old 04-10-2015, 07:30 PM
p5browne's Avatar
Quoted: 429 Post(s)
Liked: 296
Periodically check Info on the Menu. The Radiances have a habit of sometimes changing their settings due to influences of other remotes being used. Several times I ended up watching 480 instead of 1080P because of this.
p5browne is offline
post #1424 of 1429 Old 04-10-2015, 09:44 PM
jrp
jrp's Avatar
Quoted: 51 Post(s)
Liked: 57
Peter:
I think saying this is a "habit" is rather an overstatement. I have never had this happen, and there has only been one or two (rather rare) pieces of equipment that we have heard had a conflict with an IR code close enough to a Radiance code to cause an issue.
What remote control has caused you issues with this?
Jim Peterson
Lumagen
jrp is offline
post #1425 of 1429 Old 04-11-2015, 08:09 AM
p5browne's Avatar
Quoted: 429 Post(s)
Liked: 296
Peter:
Currently Samsung Remotes - ended up with a weird setting last night of 1368, instead of the usual 480 or 720. This happens usually once every week or so when my TV doesn't look right. Checking the Menu Info - settings are off. When calibrating, I tried your IR Off code, but that caused other issues. I now put a bunched up shirt in under the TV to block the XE-3D when calibrating to stop the changes. but obviously can't do this during the regular course of the day with regular viewing and changing between inputs and settings.
I then have to Reset it to Auto 2,1 again.
p5browne is offline
post #1426 of 1429 Old 04-11-2015, 08:57 AM
jrp
jrp's Avatar
Quoted: 51 Post(s)
Liked: 57
Peter:
I actually have a Samsung TV (55" 1080p60. UN55B7100WF) with a Radiance system at home and have never had any issues at all with remote conflict, including when I have run calibrations.
I wonder if the IR sensor in your Radiance is going bad. We have only have a very small number ever go bad but what happens when they do is they send out spurious pulses. Then the spurious pulses intermix with IR commands and you can get random commands that appear as valid Radiance commands and cause the Radiance to react.
Of course if you are using the wired IR input, this is not it. BTW: You could try a IR repeater and use the wired IR input to test for this as it would then bypass the front panel IR sensor. Xantech and similar repeaters work well and are not too expensive.
Send me an email to support@lumagen.com with your address and remind me which unit you have. As I recall you have a model that has the front panel IR circuit board (i.e. not a Mini or 2020) and I will send you a new IR board so you can see if perhaps your IR sensor is going bad. I will send USPS so it should not be an issue with customs getting into Canada I think.
[EDIT] It is also possible your unit is having some issue independent of IR commands. Try a "Force Update" to latest software. If a flash ROM bit has flipped, this may resolve the IR issue. A Flash ROM bit flipping can cause seemingly random behavior. So I think this is worth a shot.
Jim Peterson
Lumagen
jrp is offline
post #1427 of 1429 Old 04-24-2015, 05:10 PM
p5browne's Avatar
Quoted: 429 Post(s)
Liked: 296
The Forced FW Update appears to have cleared up about 99% of the problems.
p5browne is offline
post #1428 of 1429 Old Today, 05:06 AM
Naiera's Avatar
Quoted: 13 Post(s)
I've been experiencing a few drop-outs (picture only) over the past few weeks. The first time, the screen went completely blue for just a moment, indicating an issue with the signal in general, or more specifically an issue with the framerate. Then last night, the picture went black twice within a minute or so. Just a few seconds, but obviously not something that is acceptable should it continue to happen.
I don't remember the framerate the first time a few weeks ago, but last night it was a 1080i25 Blu-ray, output as 1080p50 from the Oppo BDP-103. I switched the scaler off and on and had no issues the next five-six hours of watching various TV shows.
Would these incidents be connected? Should I fear that my beloved scaler is dying? I have a JVC X30, so the Lumagen is absoutely vital to my setup.
The smallest Radiance (mini) is $2000 that I definitely do not have... I thought about trying the other HDMI out, trying a new 20-ish foot HDMI cable, buying a new power supply, etc. I'll do anything
Naiera is offline
post #1429 of 1429 Old Today, 07:43 AM
sjschaff's Avatar
Guessing you've checked all connections, including electrical. So, it may be the power supply or the little external brick/transformer that is on the fritz. Have you been to the Lumagen site's forum to ask about this http://www.convergent-av.co.uk/forum/
Steve Schaffer
sjschaff is online now
Reply Video Processors
