Official RadianceXD support thread - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1471 of 1495 Old 08-28-2016, 03:24 AM
Naiera's Avatar
Sorry for the late reply. I bought that cheap one and it does work great. I haven't been brave enough to see if it solved the problem to which I was referring (the workaround I made seems to get me better sound quality, so...), but it runs the scaler just fine
Naiera is offline
post #1472 of 1495 Old 08-30-2016, 04:44 PM
stephenbr's Avatar
Quoted: 174 Post(s)
Liked: 87
I have also posted this on the relevant JVC thread but thought I would also try here.
I am having trouble getting my Lumagen XD to work with my X7000/RS500. I am getting no picture/lumagen menu display etc at the moment. The JVC is indicating the following info:
Source: 480p
Deep color: 8 bit
Color Space: RGB
I have still to try a couple more cable swap outs to eliminate that problem and Jim from Lumagen has been, as is the standard from Lumagen, great with working through the problem with me.
I have done a factory reset on the Lumagen but have yet to apply a 'configuration erase' or updating the software as suggested by Jim. I will also try the Lumagen prior to my prepro rather than having it in the chain after the prepro.
In the interim (before my last change of cables testing and the above actions) I was hoping if any has any other suggestions as well as whether the fact that the feed into the JVC may require me to change some settings on the JVC
I have tried all color space options with no success but find no 'deep color' option that I can adjust on the JVC - is there an area to adjust that?
I have also tried HDMI2 with different EDID with no success.
Any assistance would be greatly appreciated.
stephenbr is online now
post #1473 of 1495 Old 08-30-2016, 06:31 PM
stanger89's Avatar
Quoted: 3371 Post(s)
Liked: 1833
Do you have another display you could hook up temporarily? If so, try setting the Radiance back to a "normal" resolution like 720p and then reconnect it to the JVC.
stanger89 is offline
post #1474 of 1495 Old 08-30-2016, 06:44 PM
stephenbr's Avatar
Quoted: 174 Post(s)
Liked: 87
Thanks stranger89. It does work on another display (with the resolution stating it is outputting 1080p) but I will double check/try your suggestion.
post #1475 of 1495 Old 08-30-2016, 06:50 PM
stanger89's Avatar
Liked: 1833
It may well be a cable issue. The Lumagen and JVC are I think both a bit more sensitive to cable issues than other products (which I say ironically because my XE actually improved my system reliability over my AVM50V doing switching). Have you tried using a short cable temporarily?
I don't know if it applies anymore, but have you tried HDMI 2 on the JVC? I know with the RS49 generation, that input supposedly worked better. I haven't actually tried my XE with my RS600.
post #1476 of 1495 Old 08-30-2016, 08:47 PM
stephenbr's Avatar
Quoted: 174 Post(s)
Liked: 87
I have tried shorter cables and longer cables and 2m cables between sources and the XD. What I haven't tried yet is a shorter cable (ie less than 10m) from the XD to the pj so that is on the testing schedule tonight.
I have also tried HDMI and the different EDIDs available on that input - unfortunately no luck.
I do appreciate the suggestions and hopefully I will get this sorted out. I just don't think I want to go to the trouble of running a new HDMI cable from the XD to the JVC as the access is horrendous (ie I have to remove roof sheeting at a very great height). I would then have to think about whether I move the XD closer to the JVC if a shorter cable resolves the issue but I am not sure I could do that.
I may end up simply leaving the XD out of the chain and using the JVC auto calc feature or pull my finger out and learn to do a manual calibration using Chromapure and the JVC CMS function.
post #1477 of 1495 Old 08-31-2016, 08:06 AM
rahull's Avatar
Source: 480p
Deep color: 8 bit
Color Space: RGB
Sometimes changing the boot sequence will solve problem as one or the other
components may not be ready to talk to the other.
rahull is offline
post #1478 of 1495 Old 08-31-2016, 04:46 PM
stephenbr's Avatar
Quoted: 174 Post(s)
Liked: 87
Thx rahull - have been trying that too but still have to try the sequence of turning on the pj last. I am having a bit of a break from testing at the moment by taking the XD out of the equation and just watch some movies instead.
post #1479 of 1495 Old 09-01-2016, 04:49 AM
stanger89's Avatar
Liked: 1833
Honestly, the last couple generations of JVC are pretty good, outside of the gamma droop which is easily corrected with the JVC autocal, you don't really need an external CMS IMO. I pulled my XE out of the chain a while ago and I don't find myself missing it.
Mike_WI likes this.
post #1480 of 1495 Old 09-01-2016, 08:04 PM
stephenbr's Avatar
Quoted: 174 Post(s)
Liked: 87
I am starting to think the same way stranger89. I just picked up a Spyder 5 PRO for a really good price so will give the JVC autocal a go. If you have any hints on using the autocal that would be great but perhaps by PM to keep this thread on topic (and I know I will have to spend some time reading the JVC autocal thread).
post #1481 of 1495 Old 09-02-2016, 04:33 AM
stanger89's Avatar
Liked: 1833
FWIW, it was 4K that got me to try my system without the Radiance, I had to bypass it for UHD Blu-ray/etc anyway, I figured I'd try it and see how things looked, and they looked remarkably similar.
There's two gigantic threads in the Projector forum with way more knowledge than I have on that subject.
post #1482 of 1495 Old 09-11-2016, 12:41 AM
stephenbr's Avatar
Quoted: 174 Post(s)
Liked: 87
Got to the bottom of my Lumagen/JVC X7000 problem - it was my 15m HDMI cable (which worked fine when using the Lumagen with my previous pj, the Sony VPL-VW95ES). I'll now compare the JVC autocalc to the Lumagen/Chromapure autocalc to see if I keep the Lumagen.
Thanks Stranger89 and rahull for your assistance (and Jim at Lumagen).
post #1483 of 1495 Old 01-12-2017, 02:26 PM
slackmack's Avatar
Quoted: 17 Post(s)
I own the original XD and I'm considering replacing my JVC RS-1 with a newer 4k projector (e-shift 4k) that supports 3D & a new A/V receiver that supports Dolby Atmos & the new DTS option. I understand that my XD will not support 3D, Atmos, etc., & 4k without an upgrade to the Pro series, so I only want to know if I can use it for auto calibration with the appropriate software or will it be totally useless now.
slackmack is offline
post #1484 of 1495 Old 01-12-2017, 03:14 PM
Mike_WI's Avatar
Quoted: 203 Post(s)
Liked: 141
XD -> Pro vs. ....
You should call Jim at Lumagen for optoins.
My RadianceXE broke, but I'm in a similar scenario of trying to decide what to do.
I converted to a Pro and added 18GHz cards.
Another option is to do without a Lumagen and use the saved money for upgraded audio and video gear as you are otherwise looking at.
There is also the Radiance Pro thread to follow.
Good luck.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #1485 of 1495 Old 01-17-2017, 06:25 PM
nesto719's Avatar
Quoted: 340 Post(s)
Liked: 53
Thinking of buying a lumagen mini and want to get some opinions on whether the investment is worth it . I have a Panasonic st60 model plasma running Comcast I have the marantz 8802 and oppo103d would the lumagen blow these two out of the water in terms of performance ?
nesto719 is offline
post #1486 of 1495 Old 01-18-2017, 09:10 AM
Steve Bruzonsky's Avatar
Quoted: 527 Post(s)
Liked: 143
I would think a Lumagen would give you a noticeably improved picture.
By the way, I have a Lumagen XE, which works fine for 1080p, that I can sell you, with 6 HDMI inputs and 2 HDMI outputs (more than the mini), and it won't cost nearly as much.
If interested, AVS PM me. (Of course I upgraded to a newer model.)
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #1487 of 1495 Old 01-18-2017, 10:03 AM
nesto719's Avatar
Quoted: 340 Post(s)
Liked: 53
is it the 3d version ?
nesto719 is offline
post #1488 of 1495 Old 01-18-2017, 12:37 PM
Quoted: 527 Post(s)
Liked: 143
Sorry, the 2d version. It can be upgraded softwarewise to 3D I believe last I heard for $300. Frankly, that affects and lowers my sales price to account for one wanting the 3D upgrade.
My home theater at:
post #1489 of 1495 Old 01-18-2017, 05:24 PM
SJHT's Avatar
Quoted: 416 Post(s)
Liked: 210
I have a XE3D sitting on a shelf and will sell it if interested. I also upgraded to a Pro. PM if interested. In the classified section. SJ
SJHT is offline
post #1490 of 1495 Old 01-19-2017, 07:24 AM
nesto719's Avatar
Quoted: 340 Post(s)
Liked: 53
I have some questions 7193525556
nesto719 is offline
post #1491 of 1495 Old 02-21-2017, 05:20 PM
stanger89's Avatar
Liked: 1833
Hey all, I've got two questions (no particular order):
Is there a way to prevent the Radiance from disrupting the output signal when input formats change? What I've already done is ensured that 1080p60 is the output format for all input formats for a given input. The reason I'm wondering is my RS600 takes an age to sync whenever the input is disrupted, and I think I remember Kris Deering saying he did something similar with his Radiance Pro.
Is there a way to reset a CMS/3D LUT without doing a full factory reset?
post #1492 of 1495 Old 02-24-2017, 03:05 AM
Gordon Fraser's Avatar
Quoted: 161 Post(s)
Liked: 172
If you've set everything to go out at same format and frame rate and resolution then i doubt there is anything else you can do...except perhaps put genlock and rate match to Off if they are on.
If you turn on service mode
MENU 0 9 1 0 you can navigate to MENU>OUT>CMS> "cms bank you want to work on" and go the greyscale section and set to default and go to the cms section and set to default. don't forget to SAVE after you've done that of course.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #1493 of 1495 Old 02-24-2017, 04:36 AM
stanger89's Avatar
Liked: 1833
Pretty sure I've got those off.
Does that clear out a color cube too?
post #1494 of 1495 Old 02-24-2017, 10:10 AM
Quoted: 161 Post(s)
Liked: 172
the cms bit does..but you need to do both the 21point and the cms resets to get rid of it fully
Convergent-AV
post #1495 of 1495 Old 02-24-2017, 10:37 AM
stanger89's Avatar
Liked: 1833
Woops, I read too fast, I missed the "and" in there.
Reply Video Processors
