DVDO EDGE !! - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #541 of 7262 Old 08-13-2008, 03:08 PM
Chuck Back's Avatar
Originally Posted by b00bie View Post
The Edge does not seem to have an RS-232 port on it, it does have a USB but acording to the OP it is for software updates only. It also appears from Josh's description that it does not have an IR eye on the front only a mini-jack connection in the rear. I called DVDO yesterday to ask about the IR codeset and what discretes will be available for use in the Edge but so far no one has gotten back to me.
Tom
EDGE does have an IR sensor. It is on the front, just underneath and to the left of the DVDO logo. It may be hard to see in a photograph because it is recessed. There is no RS232 port, but EDGE has the rear-panel mini-jack control connection.
____________________
Chuck Back
Noyd Communications Inc.
Representing VIZIO, Ultralink Cables,
K2 Mounts, Microtek, SRS Labs,
Anthony Grimani's PMI, DVDO,
Stewart Filmscreen, SANYO Projectors
Chuck Back is offline
post #542 of 7262 Old 08-13-2008, 03:09 PM
usualsuspects's Avatar
Quoted: 18 Post(s)
Liked: 30
Edge has an IR eye on the front, and a 1/8" jack for direct IR input on the back, no rs-232 port.
EDIT: Chuck Back beat me to the punch, welcome to the forums Chuck!
usualsuspects is offline
post #543 of 7262 Old 08-13-2008, 03:44 PM
b00bie's Avatar
Based on this information
Rear Panel IR Input (mini-jack) for use with existing automation systems.
And this
Q: What does the color of the power LED on EDGE mean?
A: EDGE power LED color table:
LED Description
No LED = Standby Mode
Red/Solid = No Signal Received
Green/Solid = Unknown/Unsupported Signal Received
Blue/Solid = The EDGE is processing the input
I beleive that what you are looking at is an LED and not an IR eye
Tom
BTW I blew up the photos that Josh posted and IF there is an eye there it sure is well disguised, I'll let you know for sure tomorrow. Personally I hope I am mistaken about this....
b00bie is offline
post #544 of 7262 Old 08-13-2008, 03:52 PM - Thread Starter
Josh@dvdo's Avatar
As Chuck stated, there is an IR eye on the front of EDGE, near the front panel HDMI input as well as an real panel IR input on EDGE for existing RF-to-IR or IR repeater systems.
The Status LED is at the bottom of the front right.
Josh Allen
DVDO Product Manager
Josh@DVDO.com
Josh@dvdo is offline
post #545 of 7262 Old 08-13-2008, 04:01 PM
b00bie's Avatar
Thanks Josh
b00bie is offline
post #546 of 7262 Old 08-13-2008, 11:15 PM
Raistlin_HT's Avatar
Quoted: 31 Post(s)
Liked: 30
Looks like Santa's hitting tomorrow
Raistlin_HT is offline
post #547 of 7262 Old 08-14-2008, 02:27 PM
Whisper2's Avatar
Just to Clarify a few things:
The pro will not output a 1366X768 resolution. But will output a 720p resolution to a 1366X768 capable display?> as with the vp50pro?
Does the Edge have: Saturation / Contrast controls> as the Vp-50pro?
Does the Edge have any color managment features: Gamma settings?
Are the algorithms for 1080p de-interlacing and scaling be improved for better 1080p output?
Can someone put some light about these questions?
How are the Color managment features? Are they very accurate?
Can someone display a capture screen of them?
Thanks in advanced
Whisper2 is offline
post #548 of 7262 Old 08-14-2008, 02:39 PM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Actually all those answers are in the first post and throughout this thread.
Gary J is offline
post #549 of 7262 Old 08-14-2008, 02:54 PM
Whisper2's Avatar
Sorry, but this information from the first post:
Fully programmable controls for each separate video input with non-volatile memories:
- Automatic input source detection & input priority selection
- Picture controls with memory for each input: Fine Detail, Edge Enhancement, Brightness, Contrast, Saturation, Hue
That information is everything, less precise
What do you mean accurate controls for Brightness, Contrast, Saturation and Hue for you?
Best regards
Whisper2 is offline
post #550 of 7262 Old 08-14-2008, 03:08 PM
dlm10541's Avatar
Whisper2
The product is not even on the market yet. This thread contains all thats available. Those who may know more can not talk
dlm10541 is offline
post #551 of 7262 Old 08-14-2008, 03:09 PM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
There is also Mosquito Noise Reduction.
Gary J is offline
post #552 of 7262 Old 08-14-2008, 03:15 PM
Whisper2's Avatar
Originally Posted by dlm10541 View Post
Whisper2
Ok. Thanks very much.
I read all post and there is a very little information about CMS capabilities. I'm very impatient
Well I need a chamber of tortures and a voluntary.
Best regards
Whisper2 is offline
post #553 of 7262 Old 08-14-2008, 03:17 PM
Whisper2's Avatar
I can tell you there is a scale of -50 to +50 by 1 for each if that is what you mean. There is also Mosquito Noise Reduction.
That information had not read before. It was something new
thanks
Whisper2 is offline
post #554 of 7262 Old 08-14-2008, 10:55 PM
Pia-chan's Avatar
Sssshhhh
(the scale range could change before the product is released)
"Good wine is a necessity of life for me" -- Thomas Jefferson
Pia-chan is offline
post #555 of 7262 Old 08-15-2008, 03:10 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I thought you weren't supposed to talk or post about the EDGE.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #556 of 7262 Old 08-15-2008, 06:25 AM
Q of BanditZ's Avatar
Unless the beta phase is already finished? Seeing that Amazon slot like that made me wonder if that was the case...
Great ISF Job by Chad B.
Q of BanditZ is offline
post #557 of 7262 Old 08-15-2008, 06:31 AM
ccotenj's Avatar
Liked: 101
no, the beta phase isn't finished, it just started...
my "guess" (just having followed a few threads in the past, and having dealt with testing stuff a lot in my previous life), is that the beta phase will probably take at least a few months... but that's merely a guess...
patience, glasshoppah...
- chris
ccotenj is offline
post #558 of 7262 Old 08-15-2008, 07:10 AM
shingdaz's Avatar
So in other words, thge final product won't be availble until sometime in late October early november?
shingdaz is offline
post #559 of 7262 Old 08-15-2008, 07:18 AM
ccotenj's Avatar
Liked: 101
No comment. Like I said, it's a guess. Your guess is as good as mine.
- chris
ccotenj is offline
post #560 of 7262 Old 08-15-2008, 07:41 AM
Quoted: 31 Post(s)
Liked: 30
The betas just shipped out this week.
post #561 of 7262 Old 08-15-2008, 08:02 AM
Ah. That seems more realistic.
post #562 of 7262 Old 08-15-2008, 08:29 AM
flyingvee's Avatar
and afaik, they did not ship via Amazon.
Jon
Denon DVP - everyone else loves it.
flyingvee is offline
post #563 of 7262 Old 08-15-2008, 09:12 AM
Originally Posted by shingdaz View Post
So in other words, the final product won't be available until sometime in late October early november?
That's believable and, if memory serves me right, kind of fits the typical cycle anyways.
post #564 of 7262 Old 08-15-2008, 10:51 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Well it seems if Amazon has actually shipped one all bets are off, the horse has left the barn, Katy bar the door, the genie is out of the bottle and the First Rule of the Edge Club is no longer you do not talk about the Edge.
Gary J is offline
post #565 of 7262 Old 08-15-2008, 10:57 AM
Quoted: 31 Post(s)
Liked: 30
Who said Amazon has shipped one?
The beta units didn't start shipping until a few days ago. Do you think Amazon is shipping out beta units to people?
post #566 of 7262 Old 08-15-2008, 11:16 AM
UHD Addict
aaronwt's Avatar
Quoted: 6405 Post(s)
Liked: 3961
My amazon EDGE order says "We'll notify you via e-mail when we have an estimated delivery date for this item."
So Amazon doesn't know when they will get them yet. It would have to be when they finish with the BETA.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #567 of 7262 Old 08-15-2008, 11:50 AM
Quoted: 31 Post(s)
Liked: 30
Any idea if its direct from Amazon, or is it an 'amazon store'?
Usually amazon does a decent job of offering a pre-order, or putting up an 'e-mail me when available' link, for items that aren't available yet.
For amazon stores though, its really up to them how they set it up. That said, occasionally amazon simply screws up
post #568 of 7262 Old 08-15-2008, 12:30 PM
Jeff_DML's Avatar
under the out of stock
Ships from and sold by Amazon.com.
http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
Jeff_DML is offline
post #569 of 7262 Old 08-15-2008, 12:49 PM
Quoted: 31 Post(s)
Liked: 30
Then I would assume they jumped the gun. Certainly would not be the first time.
post #570 of 7262 Old 08-15-2008, 04:29 PM
Pia-chan's Avatar
I think you meant to say that your beta just shipped out this week
Pia-chan is offline
Reply Video Processors
