DVDO EDGE !! - Page 237 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #7081 of 7262 Old 06-13-2014, 04:18 PM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Originally Posted by BiggAW View Post
If you Google it, a bunch of pages will come up. Everything I've ever seen on there is 1080p/24...
I did and everything came up the opposite - no 24p. Again, do you have a reference for that? Let's see it.
Gary J is offline
post #7082 of 7262 Old 06-13-2014, 08:50 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
Are you having fun nitpicking what I said? The ATV technically outputs 1080p60, but the content is mostly or all encoded at 1080p24. Happy now?
BiggAW is offline
post #7083 of 7262 Old 06-13-2014, 08:55 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
As to the topic of this thread, my EDGE GREEN is in BAD shape. It intermittently goes haywire, flashing at around 1hz. I tried a few tricks to get it to behave, and as of yet, it has not. I'm going to try component video input and resetting all of its settings, but I really doubt either will work. I'll try emailing Anchor Bay in a day or two if I can't get the thing to work. What a PITA!
As much as I like the DVDO EDGE GREEN, if this thing is toast, I am NOT shelling out another $500 for another one. I'll do without until I get a 4K TV, at which point the TV will have more powerful processing in it anyways...
BiggAW is offline
post #7084 of 7262 Old 06-13-2014, 11:38 PM
Turnbough's Avatar
Quoted: 35 Post(s)
That sucks..I almost bought a green but was able to pickup an original for less than a quarter of the cost. Its made connectivity to my CRT much more simple and blu-rays converted to 1080i from 1080p24 through the edge are considerably cleaner than through the players I've used. I'd buy another for the right price. $500 isn't that price for me though
Turnbough is offline
post #7085 of 7262 Old 06-14-2014, 04:25 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Yes for good reason. Credit now for getting your facts (closer to) straight.
Gary J is offline
post #7086 of 7262 Old 06-14-2014, 08:23 AM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
Well, fair enough I guess if you admit you're nitpicking. The 24p encoding on the content is what gives it the really strange look, since it acts as a framerate bottleneck compared to 1080i/60.
BiggAW is offline
post #7087 of 7262 Old 06-14-2014, 08:25 AM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
Yeah. You're doing basically the opposite of what I'm doing. My main use is trying to do as much work on Comcast HDTV before sending a 1080p signal to my TV. Other than the power savings aspects, the OG EDGE is better, as it handles 240p on the composite inputs as well (N64).
I don't see any OG Greens for sale on Ebay, and the Greens are in the $300+ range.
BiggAW is offline
post #7088 of 7262 Old 06-14-2014, 09:50 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
I don't see it nor do I see such complaints unless you are talking about the Edge which I threw away a while ago.
Gary J is offline
post #7089 of 7262 Old 06-14-2014, 03:48 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
It's not so much of a complaint as an observation. If you're used to watching a show in 1080i/60 and all of the sudden it's in 1080p/24, it WILL look really odd. That has nothing to do with the EDGE, it doesn't matter what processes it, the look will be different.
BiggAW is offline
post #7090 of 7262 Old 06-15-2014, 03:43 PM
dstroot's Avatar
Same issue with mine - it warms up after 15 - 30 minutes it goes haywire, picture turns to green snow. Had to replace it.
Could this be the power supply going? Anyone want to buy a semi-working Edge and try the mouser CFM60M050 power supply swap?
dstroot is offline
post #7091 of 7262 Old 06-15-2014, 06:23 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
Yeah, that's almost what I'm wondering. How difficult is the PSU swap? For $43, it's almost worth trying...
BiggAW is offline
post #7092 of 7262 Old 06-16-2014, 07:38 PM
audiodane's Avatar
Quoted: 115 Post(s)
Liked: 77
Depending on what you want for it, I'd be happy to buy it, swap the PSU, and see what happens..
..dane
audiodane is offline
post #7093 of 7262 Old 06-18-2014, 08:59 PM
Blacklac's Avatar
I've had the snow & green screen issue for over a year and never heard back from any emails I've sent to attempt to get it fixed/replaced. :/. Would certainly drop ~$40 if it is indeed a PSU and its plug and play! Mine isn't a Green model though.
Blacklac is offline
post #7094 of 7262 Old 06-19-2014, 05:18 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
Mine was close to the warranty period, so they agreed to fix it. It's going to take me at least a week just to retrieve the box to RMA it, so it will probably be a month before I get it back, but I'm pretty happy that it will get fixed one way or another.
BiggAW is offline
post #7095 of 7262 Old 06-19-2014, 08:20 PM
dstroot's Avatar
..dane
How does $75 plus shipping sound? Comes with new remote and cables - I just swapped boxes. Let me know. Cheers.
dstroot is offline
post #7096 of 7262 Old 06-20-2014, 07:39 PM
Turnbough's Avatar
Quoted: 35 Post(s)
I've only had a green screen flash when running my blu-ray player set to original resolution for blu-ray and DVD. Seems like 10-20 handshakes when on that setting green screen each time..switched back to 1080/24 for both and my issues seem to be resolved. Gotta say I love this box used the fine cross hatch test pattern to tighten up my convergence on my ws-65813 very nice
post #7097 of 7262 Old 06-23-2014, 10:40 AM
audiodane's Avatar
Quoted: 115 Post(s)
Liked: 77
Hey dstroot..
I have had a few things come up on this end where I probably won't have sufficient time to get to it anytime soon.. But if anyone else is interested, here's what I was thinking.. If they want to take this idea and run with it and make you an offer, I'll leave it up to them.
The major issues is that I don't know what the problem is. If it's a power supply, and I buy yours for $75 and sink in $50 more, then I'm up to $125, and that's about what they go for on eBay, but before eBay fees, shipping costs, etc. I'll be honest, I'm looking to flip it like a house; buy, repair, sell. I do this often for various types of electronics for some extra spending money. If the problem is NOT the power supply, then I'm out the cost of the unit AND the replacement power supply. So it's not without risk.
So from the buyer's end, here is what I was thinking..
I/Someone can offer to basically take it off your hands for you and cover the cost of economy shipping charges (ups ground or usps parcel post). Either of those shipping options should run somewhere between $16 and $30. I can paypal you that plus $5 extra (more than enough for paypal fees). So we're talking somewhere in the $20-35 range, shipped. A power supply will add another $50, and if that fixes it, I can sell it and make about $25.. If it doesn't fix it, I can re-sell both pieces separately (broken edge and like-new power supply) and try to break-even.
Unfortunately, as I said, I'm going to have to pass on it at this time, but I think the above scenario is a reasonable one for anyone else who wants to have a go at it.
cheers,
..dane
post #7098 of 7262 Old 06-23-2014, 02:46 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
It costs $22 and change to ship a DVDO EDGE at the Post Office in case anyone wants to know. I just shipped mine back to California for them to look at.
BiggAW is offline
post #7099 of 7262 Old 06-25-2014, 07:18 PM
Turnbough's Avatar
Quoted: 35 Post(s)
If anyone is interested eBay has a few new old stock original edge processors for sale priced same as green models or best offer
post #7100 of 7262 Old 06-26-2014, 06:35 AM
FragZero's Avatar
I got one for 255 USD + shipping. It just came in and it looks brand new. No scratches at any connector or on the remote.
(I did a best offer on the add Turnbough mentions)
FragZero is offline
post #7101 of 7262 Old 07-10-2014, 08:58 AM
Skrill's Avatar
Quoted: 255 Post(s)
Liked: 76
Velodyne SMS-1/ Edge Green / Sony PJ not playing nice (no video)
Hey guys. I just picked up a used SMS-1 and it seems to be functioning correctly (fires up, plays test tones, etc), but I can't get the video to display from my projector. I hope it is not the case that the video is so low res that it won't display -- but here is my signal change:
SMS-1 via S-video out (or composite - I tried both) --> DVDO Edge Green S-Video in (or Composite in) -- input set correctly relevant input ---> Sony VPL-HW55ES via HDMI output from Edge.
Now the Edge sees the signal from the SMS, and it's LED goes from Red (no signal passed) to Blue (signal being passed). But the Sony will just to go to blank (sometimes you will see the video for a split second before it blank). In fact, I can't even get the Sony's menu (or the Edge's menu) to display. It seems to be an output/input compatibility issue between the Edge and Sony (which otherwise the two work perfectly together).
Any ideas -- do I need to change the output signal (which currently defaults to 1080p/60)? Is it an HDCP issue? Is there a new school and old school incompatibility between the Sony or Edge and the SMS-1?
Help!
CT
Skrill is offline
post #7102 of 7262 Old 07-10-2014, 09:44 AM
Hyrax's Avatar
Quoted: 115 Post(s)
Liked: 51
What do you see when you press the Info button?
Perhaps Sony requires HDCP on all 1080p devices ... try setting the output for this input to be 480p or 720p.
Hyrax is offline
post #7103 of 7262 Old 07-10-2014, 10:47 AM
Skrill's Avatar
Quoted: 255 Post(s)
Liked: 76
Thanks for trying to help. I will do that.
When it goes blank it kind of locks up the display. The DVDO menu and info buttons work (when I switch back to another input the menu is being displayed -- i.e., pushed out by the Edge), but the Sony refuses to show anything when S-Video is selected.
I know I should refer to the manual -- but is there a way to set the output resolution for S-Video input only? Assuming so -- I will try that tonight.
Skrill is offline
post #7104 of 7262 Old 07-11-2014, 07:09 AM
Skrill's Avatar
Quoted: 255 Post(s)
Liked: 76
For the knowledge base (and other Edge owners):
Just an update -- it seems like the when the Edge is passing the video signal of the SMS-1, the Sony PJ refuses to play nice. Even if I set the output resolution to 480p or 780p on the Edge, locked/unlocked the framerate, on/off with HDCP, etc., etc.
So I took the Edge out of the signal chain and plugged the SMS-1 video straight into my Onkyo SR805 -- and then the projector into the HDMI out on the 805. That worked ... so all is good. Odd though that the Edge somehow won't pass (or the Sony won't accept) the signal
Skrill is offline
post #7105 of 7262 Old 07-29-2014, 06:28 AM
Ayla's Avatar
Quoted: 31 Post(s)
Liked: 34
Is the DVDO Edge 101 the same model as the Edge Green?
And, can the Edge 101 convert from 1080p@24Hz input to 1080p@60Hz output, and from 1080p@50Hz to 1080p@60Hz?
/Martin
Ayla is offline
post #7106 of 7262 Old 08-19-2014, 07:12 PM
Turnbough's Avatar
Quoted: 35 Post(s)
Edge 101 is the original edge not the green model there are some differences between the models.
I have the original and use it to convert 1080p@24 blurays into 1080i and works perfectly should do the same at 1080p
I have never used PAL equipment so I can't comment on that..my knowledge of the unit is pretty basic but its responded well with all of my equipment and works perfectly in my setup
post #7107 of 7262 Old 10-19-2014, 08:51 AM
headcase151's Avatar
Quoted: 18 Post(s)
I`m looking at getting an Edge.I want to split the signal.Sending the audio to my Pioneer receiver.Then pass the 3D signal to my projector.Can this be done with the Edge.Thanks in advance.
headcase151 is offline
post #7108 of 7262 Old 10-19-2014, 04:15 PM
BiggAW's Avatar
Quoted: 567 Post(s)
Liked: 140
The EDGE Green has a 3D mode, but it doesn't do any processing when the 3D mode is enabled. I've sent 3D video to my Sharp LE8470U while sending audio to my AVR, so I would think it would work with a non-3D AVR, but I'm not 100% sure, as I think mine is 3D capable.
BiggAW is offline
post #7109 of 7262 Old 10-19-2014, 07:07 PM
Quoted: 18 Post(s)
Thanks.I just want to bypass my AVR,it HDMI 1.2.I`m ordering one tomorrow.
post #7110 of 7262 Old 10-19-2014, 07:35 PM
Turnbough's Avatar
Quoted: 35 Post(s)
If your using the audio HDMI to the receiver and the video HDMI to the projector you'll just have to set it up through the menus when you do your initial setup and don't for get to activate the 3D pass-through.. You should be good to go. I'd check and make sure your unit also has the latest firmware. it should but you don't want to have to unplug everything later if you find out it doesn't.
Reply Video Processors
