DVDO EDGE !! - Page 238 - AVS Forum
post #7111 of 7120 Old 10-20-2014, 03:34 PM
BiggAW's Avatar
Quoted: 213 Post(s)
Liked: 57
Originally Posted by Turnbough View Post
If your using the audio HDMI to the receiver and the video HDMI to the projector you'll just have to set it up through the menus when you do your initial setup and don't for get to activate the 3D pass-through.. You should be good to go. I'd check and make sure your unit also has the latest firmware. it should but you don't want to have to unplug everything later if you find out it doesn't.
Correct. Mine was already set up with 3D pass-through and separate audio and video, and it worked with my TV and AVR...
BiggAW is offline
post #7112 of 7120 Old 10-22-2014, 06:36 PM
headcase151's Avatar
I got my Edge today.Still setting it up.3D works great.I am having some issues with gaming.I`ll keep tinkering for now.Probably a setting.
headcase151 is offline
post #7113 of 7120 Old 10-24-2014, 07:38 PM
hometech99's Avatar
Question Edge wont turn on
I have an original Edge.
The LED on the front is dim red, and it flickers a bit when using the remote, but it wont turn on.
If I hook up a USB and use the paperclip on the service port, I DO see the Edge on my PC and can upgrade the firmware.
I unplugged the cable, and still the same thing.
It wont power up for use.
So, can this even be the power supply issue of I can see it on my PC and transfer firmware to it?
I dont want to spend the money for a new PS if thats not it.
btw--this has been seeing clean power since bought, through an APC S20BLK, and has been on an open air rack (not in a closet).
hometech99 is offline
post #7114 of 7120 Old 10-24-2014, 08:15 PM
Turnbough's Avatar
Quoted: 27 Post(s)
I've never had a problem with my edge powering on. It just won't shut off. I'm assuming your feeding it a signal while you trying to power it on and still get nothing. The only time I've had anything close to what your describing I didn't have any signal going to it and it just stayed red and unresponsive.
Turnbough is offline
post #7115 of 7120 Old 10-30-2014, 05:25 PM
dvdguyjt's Avatar
EDGE Owner's Manual
Hello -
I just purchsed and EDGE from craigslist ($125 steal if I may say so). I'm looking for a full copy of the owner's manual that I can download. The website no longer has it available.
Does anyone know where I might find it?
dvdguyjt is offline
post #7116 of 7120 Old 10-30-2014, 06:22 PM
Turnbough's Avatar
Quoted: 27 Post(s)
You should be able to use the owners manual for the edge "green". You can download the manual from their website. Basically the same unit minus 1 front HDMI input, a different power supply, and 240p processing(may have been fixed in firmware). I have an original edge so I've never looked.
post #7117 of 7120 Old 12-22-2014, 09:40 AM
dvdguyjt's Avatar
Thanks. I found it.
A question....I have the EDGE connected to my TV via HDMI and an optical cable to my receiver (no HDMI there). I only use the receiver when watching Blu-Ray. Otherwise I use the TV sound.
Is there a way to get the EDGE to output audio over both connections? I have to manually switch it to optical to get recognition from the receiver.
I tried 'auto select' audio, but it always selects the HDMI that's going to the TV.
Any thoughts....
dvdguyjt is offline
post #7118 of 7120 Old 12-22-2014, 11:17 AM
Turnbough's Avatar
Quoted: 27 Post(s)
Thanks. I found it.
Any thoughts....[/QUOTE]
I have an older setup my Mitsubishi only has a DVI input. I run video over HDMI to DVI cable and run audio over the optical out. Unfortunately I don't even have a way to test to try and help you figure that out. Wish I could help
post #7119 of 7120 Old 12-22-2014, 12:37 PM
BiggAW's Avatar
Quoted: 213 Post(s)
Liked: 57
Originally Posted by dvdguyjt View Post
Thanks. I found it.
Any thoughts....
Use your AVR all the time. You have it, you may as well use it and not use the crappy TV speakers.
BiggAW is offline
post #7120 of 7120 Old 01-02-2015, 04:55 PM
wildchild22's Avatar
I am looking for a dvdo edge 101 not green. If anyone has one they want to sell PM me with the info.
wildchild22 is online now
Reply Video Processors
