DVDO EDGE !! - Page 243 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #7261 of 7262 Old 07-01-2017, 01:01 PM
Hyrax's Avatar
Quoted: 115 Post(s)
Liked: 51
Thanks for the info. Is this the sort of thing (the power supply fix) an idiot like myself can do?
Hyrax is offline
post #7262 of 7262 Old 07-02-2017, 07:47 AM
Glyn M RucK's Avatar
Indeed it is. Remove 4 casing screws at the rear & slide metal cover back to release. Unplug power supply. One fly lead to power socket, one fly lead to main board. Remove 4 white plastic screws attaching PSU to posts. Remove & replace. Put plastic screws & shield back in place. Replug & you are done. Test & replace lid. Dead simple.
ID:	2214169   Click image for larger version
Name:	IMG_1238 - Copy.JPG
ID:	2214177   Click image for larger version
Name:	IMG_1238 - Copy1.JPG
Glyn M RucK is offline
Reply Video Processors
