DVDO EDGE !! - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #721 of 7262 Old 08-24-2008, 03:58 AM
shingdaz's Avatar
Originally Posted by Bear5k View Post
There seems to be a lot that gets confused in this discussion of DVDs, connections and PReP. What people should want is a clean, 480i signal delivered over HDMI. A 480p signal that does good, or simply "obvious" so PReP can work its magic, deinterlacing is next best. Bad DVD players come in many resolutions, and people should want a decent one, or one that can be made decent.
I don't understand by what people mean by bad 480i de-interlacing from the DVD player?...if 480i is bad then 480p from a bad dvd player is just as bad...where in the signal do things improve?...480i/1080i both have the original interlkaced signals already...so why would the Vppro have a hard time de-interalcing something it's supposed to do perfectly?...and why would you pick 480p output of the player if it de-interlaces to 480p poorly also?....that doubles the conversion processing power required by the pro.
IMO 480i/1080i output present the original interlaced frames of the signal, nothing done bythe dvd player...the pro then does it's job de-interlacing the signal to progressive frames...thats it. Some might argue that the pro should upscale the image itself instead of the dvd player upscaling to 1080i...but if there's double the information in the signal already then all the pro has to do is reduce the frequency to match your set's output @ 720p etc. Of course the pro's algorythms could reduce t he quality of picture slightly due to bad upscaling algorythms from the player...but in most cases it could complement the upscaling algorythms of the players also, somthing it could lack due to different algorythms etc. So when coupled with another upscaling device you can have double the upscaling power without sacrifing the pro's resources to do it itself.
I find 1080i SD signals appear more smoother, especially when viewing subtitiles and letters on certain show/ commercials...there is less of a blocky effect I find compared to 480i SD signal that happens to introduce these artifacts pitifully.
s
shingdaz is offline
post #722 of 7262 Old 08-24-2008, 04:33 AM
ccotenj's Avatar
Liked: 101
- paragraph 1: that's an interesting theory, but incorrect. you always want to provide the "best" scaler/interlacer/deinterlacer in the chain the "cleanest" (i.e. the most unprocessed) signal. you don't "double your upscaling power" merely by putting 2 scalars in series.
- paragraph 2: not sure what you are referring to here. if you are referring to the same broadcast being scaled by your stb to 1080i vs your stb passing 480i straight through, the only thing this means is that the processing in the stb is "better" than the one in the tv...
- chris
ccotenj is offline
post #723 of 7262 Old 08-24-2008, 04:55 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Likely worse. De-interlacing is the difficult part and the primary reason people pay so much for processors like the DVDO whether it's de-interlacing an interlaced signal or PRePing a progressive signal.
Gary J is offline
post #724 of 7262 Old 08-24-2008, 05:36 AM
dlm10541's Avatar
Since most DVD players do not output 480i over HDMI but only 480P, PReP will reconsruct the original 480i and the deinterlace itself genenerally doing a better job than in the DVD.
If the original 480i signal is corrupt there is not much that can be done
dlm10541 is offline
post #725 of 7262 Old 08-24-2008, 05:40 AM
cpcat's Avatar
Originally Posted by the_dudeman View Post
Please, please elaborate for my benefit. The others here may know what you mean, but I would like to know your thoughts and experiences.
Thanks, for any feedback.
dudeman
A quality VP can improve most any signal that requires deinterlacing,scaling, or benefits from other post processing such as noise reduction. This includes just about any readily available signal out there.
Those with larger displays (or who sit closer to them) will likely see the most difference.
Improve the source signal and all the better.
cpcat is offline
post #726 of 7262 Old 08-24-2008, 06:35 AM
Clark Burk's Avatar
Quoted: 265 Post(s)
Liked: 317
Originally Posted by b00bie View Post
The Beta forum is on a DVDO website not AVS
Tom
If that is the case then they are doing a very good job of keeping it secret.
Clark
Clark Burk is offline
post #727 of 7262 Old 08-24-2008, 06:48 AM
b00bie's Avatar
I believe that is the idea
b00bie is offline
post #728 of 7262 Old 08-24-2008, 07:47 AM
rudolpht's Avatar
Originally Posted by Pia-chan View Post
It is advisable to not overemphasize the value of 480i over HDMI when choosing a DVD player to hook up to the EDGE. The picture generated by the EDGE from a crappy DVD player outputting 480i will still be inferior to a quality DVD player outputting 480p.
OK, how about a 480i HDMI outputting player like mine, a Pio 59AVi, that isn't a crappy outputting HDMI player? I assume it WILL be preferable to output 480i vs 480p then let the edge do it's PReP magic.
It will be interesting to test 480i HDMI, 480p HDMI and Component on this player (and A/B the XA-2 Reon of the same).
Regardless of Secret Forums for Betas (it's still secret if you don't have privileges to read it... at least from common sense) the EDGE seems like a genuine bargain.
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #729 of 7262 Old 08-24-2008, 08:36 AM
the_dudeman's Avatar
Well I really, really hope that's true. As far as I can tell my hr21 does a poor job of scaling. I have put the display in just scan mode and what I end up with is underscan and the edges of the picutre have all kinds of noise and are not straight. So I have to run the display in 16:9 mode as to avoid this horrible underscan. The display does a slightly better job of scaling but of course does nothing for the PQ. I have tried many different settings, but nothing works very well because of course the signal is crummy.
So if a VP can help this crummy signal, it will be great, as I can do nothing to send the VP a better signal. I don't need the VP for anything except dtv because as I mentioned, my htpc Blu-ray/HD DVD does an incredible job.
This is off topic a little, but I had a thought about satellite capture cards. Do you think that dtv SD would look any better going through such a card and being displayed by the Radeon graphics card in my htpc? I would think the Radeon with all of the Avivo, Anti Aliasing. Anistropic Filtering and color adjustments might clean up the picture. Everything that is displyed through my htpc over HDMI looks great.
Thanks for any input,
dudeman
the_dudeman is offline
post #730 of 7262 Old 08-24-2008, 08:41 AM
Bear5k's Avatar
For the many who seem unconvinced:
There are many ways to "deinterlace" a 480i signal. For film-based content, that is interlaced properly to begin with, simple IVTC (inverse telecine) is all that is required. However, you can also get Bob, Weave and more advanced Motion Adaptive and Motion Compensated (I'm simplifying) algoritms. You want to feed ANY VP (not Edge-specific) a 480i signal from a 480i source because there has been potentially less bad deinterlacing (aka processing) applied to the signal.
And yes, it is possible to get a good 480i signal from a DVD player which would otherwise provide a mediocre deinterlaced signal (e.g., the original Oppo HDMI DVD player). It is also possible to get a bad 480i signal out of a DVD player where the 480p would be preferred (many DVD players do not create a "stable" 480i signal since it is essentially a 480p signal over HDMI - but that is a different topic).
Bill
Color accuracy evangelist and CalMAN insider
Bear5k is offline
post #731 of 7262 Old 08-24-2008, 08:55 AM
Pia-chan's Avatar
In your case I would choose to output 480i, but I think you'll be unable to identify a difference in picture quality when you test 480p output to the EDGE.
"Good wine is a necessity of life for me" -- Thomas Jefferson
Pia-chan is offline
post #732 of 7262 Old 08-24-2008, 09:51 AM
petmic10's Avatar
Originally Posted by petmic10 View Post
Josh,
What does the EDGE do with a YCbCr 4:4:4 signal?
My Pioneer BDP-51FD can output a YCbCr 4:4:4 and YCbCr 4:2:2 signal
and I am interested in knowing what the EDGE will do with a 4:4:4 color
space?
My apologies if this has been answered.
Mike
Originally Posted by fyzziks View Post
4:4:4 has the same colorspace as 4:2:2, it's just been interpolated to full resolution. Why not send the Edge the 4:2:2 data direct from the disk, uninterpolated by your BD player? it just has to downsample back to 4:2:2 for processing. Most likely no loss of data, just extra data transferred and extra processing to no purpose...
Thanks for the response.
My whole reason for sending a 4:4:4 signal is one of the Pioneer 51
features is upscaling 8 bit to 12 bit and I was under the impression
that the 4:4:4 setting in the pioneer would perform this upscaling?
I would like to have the ability to choose between the two.
I would still like to get Josh's take on what the EDGE does with
a 4:4:4 color spcae signal?
Can this be added with a firmware upgrade? or at least pass it through
untouched?
Display: LG 65E7P 65" OLED
Blu-ray player: OPPO UDP-203, OPPO BDP-93
Processor: Onkyo PR-SC885
Amplifier: Emotiva IPS-1 150Wx7
Game Console: Xbox One, PS4
Speakers: Mythos ST(Fronts), Mythos Ten(Center), Mythos One(Rears)
petmic10 is offline
post #733 of 7262 Old 08-24-2008, 03:37 PM
T2k
T2k's Avatar
Somehow that memo never made it to me...
T2k is offline
post #734 of 7262 Old 08-24-2008, 04:01 PM
rudolpht's Avatar
Looking forward to trying it
Tim
rudolpht is offline
post #735 of 7262 Old 08-24-2008, 04:34 PM
cpcat's Avatar
Welcome sir.
To the EDGE.
cpcat is offline
post #736 of 7262 Old 08-24-2008, 04:46 PM
cpcat's Avatar
Bill
I thought bob, bob/weave, motion adaptive and motion compensated were methods of video deinterlacing (not film)?
Anyhow, I agree with everything you said except that.
However, I also think that it may be POSSIBLE to obtain identical PQ with the current PReP technology with either 480i or 480p output.
Disclaimer: this is based on reports from the VP50pro forum and does not suggest any personal experience of mine.
cpcat is offline
post #737 of 7262 Old 08-24-2008, 05:48 PM
Pia-chan's Avatar
Nice
Pia-chan is offline
post #738 of 7262 Old 08-24-2008, 06:53 PM
Pia-chan's Avatar
This weekend I received an online retailer's Fall 2008 catalog in the mail and was surprised to find the EDGE on page 4. It seems strange to me that online retailers are already offering this product for sale. I understand the concept of a pre-order, but the EDGE is still in beta testing with no known release date, which obviously means there isn't a tentative ship/deliver date for potential customers.
I guess if there are folks out there that want to give these retailers a short term loan @ 0.00% interest, so be it.
Pia-chan is offline
post #739 of 7262 Old 08-24-2008, 07:05 PM
cpcat's Avatar
I'm sure DVDO has a target release for marketing purposes. There's probably some sort of time cushion built in as well.
cpcat is offline
post #740 of 7262 Old 08-24-2008, 07:57 PM
DCIFRTHS's Avatar
Some retailers, and the only ones I would buy from, don't charge you until your item ships.
Do we really know how far along the testing is? Read Josh's post here.
DCIFRTHS is offline
post #741 of 7262 Old 08-25-2008, 01:20 AM
T2k
T2k's Avatar
What a nonsense. Of course there's a (more than tentative) release date - do you think companies develop products and release them randomly, whenever they suddenly think it's OK?
HINT: if there's something you don't know about it doesn't mean it doesn't exist - there's a world beyond your bubble...
You must be buying in some shady stores because any retailer I know won't charge you until they ship your order.
T2k is offline
post #742 of 7262 Old 08-25-2008, 05:12 AM
UHD Addict
aaronwt's Avatar
Quoted: 6416 Post(s)
Liked: 3965
Amazon certainly hasn't charged my card yet for my EDGE preorder through them.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #743 of 7262 Old 08-25-2008, 05:43 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
They can not by law.
Gary J is offline
post #744 of 7262 Old 08-25-2008, 06:00 AM
UHD Addict
aaronwt's Avatar
Liked: 3965
Then many merchants break the law.
aaronwt is offline
post #745 of 7262 Old 08-25-2008, 06:48 AM
T2k
T2k's Avatar
By which law?
T2k is offline
post #746 of 7262 Old 08-25-2008, 07:02 AM
flyingvee's Avatar
well, then Menards, Lowes, and Home Depot all qualify as "shady stores", since every order I placed this summer (replacing what the river took away during our floods) required a hundred percent deposit. That indeed WAS charged to my cc.
otoh, DVDO has never charged my card until the item actually shipped.
Jon
Denon DVP - everyone else loves it.
flyingvee is offline
post #747 of 7262 Old 08-25-2008, 07:59 AM
1msPixel's Avatar
Watching this thread, and being a "newbie" to all of this, it seems to me that
1) One does not want to waste money on a video processor if one's goal is merely to upgrade a horribly compressed signal such as that which comes from a cable company.
2) The best application for a video processor is in upgrading a 480i DVD player's signal
If number 2 above is correct, then it seems to me that if one wants to guarantee elimination of any processing at all in the DVD player, modification of the player to have a Serial Digital Interface (SDI) output and utilization of processor that can accept an SDI input which the DVDO edge will not do, but other DVDO products will do, is the best choice.
Any expert thoughts on or corrections to my statements?
1msPixel is offline
post #748 of 7262 Old 08-25-2008, 08:06 AM
cat6man's Avatar
hi,
i disagree somewhat with your first point.........i hear stories of horribly compressed satellite signals but my experience with cable is that my vp50pro
is fantastic with basic cable.......huge improvement on my comcast channels as well as for DVDs
on the other hand, my experience is that comcast's signal is not as badly compressed as some satellite channels.........your mileage may vary
cat6man is offline
post #749 of 7262 Old 08-25-2008, 08:13 AM
scsiraid's Avatar
Originally Posted by cat6man View Post
hi,
Your statement agrees with what others have told me. A VP may not do for cable what it can for DVD... but it is an improvement nonetheless.
scsiraid is offline
post #750 of 7262 Old 08-25-2008, 08:40 AM
cat6man's Avatar
imho, i think it does as much if not more for my cable........it has made my basic, non-HD channels, actually enjoyable which is more than i ever expected.
i see none (as in zero) of the horrible motion artifacts often seen in tv displays at stores (usually due to compressed satellite channels).
cat6man is offline
Reply Video Processors
