DVDO EDGE !! - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #901 of 7255 Old 09-04-2008, 07:28 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
It seems pretty simple to me. If you have non-HDMI equipment you like why get rid of it?
And even some people with all HDMI have a wiring rats nest.
Gary J is offline
post #902 of 7255 Old 09-04-2008, 07:51 AM
dlm10541's Avatar
Darn Power cords and speaker wires anyway
dlm10541 is offline
post #903 of 7255 Old 09-04-2008, 08:38 AM
iMbEst's Avatar
anybody know where can I turn to if my beta unit is giving problem? I need it for an important event, and now it's down
iMbEst is offline
post #904 of 7255 Old 09-04-2008, 08:48 AM
bsntn99's Avatar
Call DVDO directly or check out link below. For other folks, they have the complete owners manual and setup guide online as well.
http://www.anchorbaytech.com/dvdo_edge/support.php
bsntn99 is offline
post #905 of 7255 Old 09-04-2008, 09:03 AM
dlm10541's Avatar
If you are part of the beta program how can you possibly not know where to go. Somethings fishy here
dlm10541 is offline
post #906 of 7255 Old 09-04-2008, 09:29 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
And you've cast your bait.
Gary J is offline
post #907 of 7255 Old 09-04-2008, 09:33 AM
scsiraid's Avatar
I have a question.... Hopefully somebody or perhaps Josh can comment...
Suppose I have a display that supports both 1080p60 and 1080p24. Further suppose that I have set the display output format as 'auto'. If Edge gets an input that is 'film' based either by the fact thats its 1080p24, by direct 3:2 cadence detection for 'i' inputs or by Progressive Cadence Detection... will it automatically output a 1080p24 signal? Will it also automatically output 1080p60 when its input is 'video' based?
There has been a lot of discussion about the manual selection of output format based on input format but the manual indicates an auto mode which may make an output selection based on the input type....
scsiraid is offline
post #908 of 7255 Old 09-04-2008, 12:37 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
He was OFFICIALLY banned from the program...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #909 of 7255 Old 09-04-2008, 01:25 PM
flyingvee's Avatar
good question - wouldn't it be dependent on your display's edid implementation? and what it "told" the input device/Edge was its native res?
or - does it just default to highest res possible - that's the case with my Wyman IFB card...when I plug a PS3 into it, the PS3 will automatically feed it 1080p60 if I let it, since that is what the card tells my PS3.
Jon
Denon DVP - everyone else loves it.
flyingvee is offline
post #910 of 7255 Old 09-04-2008, 01:54 PM
Pia-chan's Avatar
As was explained by Josh in earlier posts, the display will communicate via EDID a "preferred" resolution, which may or may not be the native resolution. When set to Auto, the EDGE will output the "preferred" resolution.
"Good wine is a necessity of life for me" -- Thomas Jefferson
Pia-chan is offline
post #911 of 7255 Old 09-04-2008, 01:59 PM
Pia-chan's Avatar
and joerod ate it
Pia-chan is offline
post #912 of 7255 Old 09-04-2008, 02:09 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Hook, line and sinker!
Gary J is offline
post #913 of 7255 Old 09-04-2008, 02:44 PM
cpcat's Avatar
Don't think so based on what has been said here.
I'm not aware of any VP's right now that will do this. One problem is that if you are watching a film source and you go to commercial you'll get re-sync and loss of picture during commercials. That's pretty distracting and would probably result in a flood of calls to tech support.
cpcat is offline
post #914 of 7255 Old 09-04-2008, 04:48 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
(I might be wrong, but) I think the Crystalio II has an automatic output profile selection based on what content is detected. I don't know though how long the detected signal has to be active to make the processor switch.
Fudoh is offline
post #915 of 7255 Old 09-04-2008, 05:25 PM
cpcat's Avatar
That won't distinguish between 1080i video and film, or 480i video and film, or.. well you get the idea.
cpcat is offline
post #916 of 7255 Old 09-04-2008, 07:08 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
I don't follow, sorry. The VP50/50Pro does offer automatic output profile selection based on the incoming signal (480i, 1080i etc), the Crystalio 2 has an automatic output profile selection which can be based on the detection of film or video material. In other words: you apply 1080p24 to film based 1080i content and 1080p60 to 1080i video based content. If you're watching a movie on TV it will output in 1080p24 during the movie and 1080p60 during a newsbreak (or similar).
Wasn't this what you were asking for earlier ?
Fudoh is offline
post #917 of 7255 Old 09-04-2008, 07:19 PM
cpcat's Avatar
Many VP's have per input output configuration. This isn't what is being referred to.
The Crystallio II as you describe it does what the OP wants (assuming you are an owner and/or this is reliable info). Seems like it would be somewhat clumsy to me, but I suppose some folks might be ok with it.
The problem with 1080p24 output from broadcast sources is that it often doesn't work consistently due to the cadence breaks, frame drops, etc. which are present in broadcast material (and not present in recorded material).
cpcat is offline
post #918 of 7255 Old 09-04-2008, 07:25 PM
T2k
T2k's Avatar
Originally Posted by Pia-chan View Post
and joerod ate it
T2k is offline
post #919 of 7255 Old 09-04-2008, 07:40 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
Not only that but broadcast sources frequently alter the length of programming by dropping frames at regular intervals on purpose.
Gary J is offline
post #920 of 7255 Old 09-04-2008, 09:34 PM - Thread Starter
Josh@dvdo's Avatar
Originally Posted by Abq-Pete View Post
Josh,
I have a question on the functionality of the HDMI outputs. On page 51 of the manual, the decision logic for the Auto Select mode are very clear. Can you tell me what happens on the Audio HDMI output when you select Audio Out On Video HDMI? Is there no signal sent or is there a duplication of the audio from the Video HDMI?
Conversely, when you select Audio Out on Audio HDMI, the Video HDMI has the audio signal stripped from it?
Thanks and regards, Peter
If the HDMI audio/video output is selected then the HDMI audio only output is muted and if the HDMI audio only is selected then the HDMI audio/video output is muted. This is done so that an incompatible audio format is not sent to a display, like Dolby TrueHD, or so that an AV Receiver does not receive a "dumbed down" audio signal that is compatible with the display.
Josh Allen
DVDO Product Manager
Josh@DVDO.com
Josh@dvdo is offline
post #921 of 7255 Old 09-05-2008, 09:12 AM
Abq-Pete's Avatar
Thanks Josh!
Regards, Peter
Abq-Pete is offline
post #922 of 7255 Old 09-05-2008, 09:24 AM
choddo2006's Avatar
I'm pretty sure the C2 can do this, as he says
choddo2006 is offline
post #923 of 7255 Old 09-05-2008, 10:52 AM
T2k
T2k's Avatar
It's perfect as it is.
T2k is offline
post #924 of 7255 Old 09-05-2008, 10:54 AM
montyward's Avatar
I'm interested in the EDGE, but output from an HTPC to a 720P DLP. I assume it will improve the scaling of the Video Card in my HTPC and provide a cleaner picture but would it be more ideal to somehow have native output? (480i for SD/DVD, 720p and 1080i) Just curious how much of an improvement I will see. On some animation, family guy, kids cartoons, I see terrible noise, typically lines that seem to move, and was hoping that problem would be fixed.
montyward is offline
post #925 of 7255 Old 09-05-2008, 05:38 PM
cpcat's Avatar
Yep.
See here:
http://www.avsforum.com/avs-vb/showt...7#post14507227
cpcat is offline
post #926 of 7255 Old 09-05-2008, 06:38 PM
ccotenj's Avatar
Liked: 101
the following isn't unique to the edge, it's true of all vp's... you want to feed it the most unprocessed signal possible...
- chris
ccotenj is offline
post #927 of 7255 Old 09-06-2008, 04:01 PM
jlanzy's Avatar
Quoted: 242 Post(s)
Liked: 65
Any opinions if this unit would produce a better picture (i.e. deinterlacing/scaling) of 480i SD DVD/Cable to 1080p than the processor in the JVC RS2?
jlanzy is offline
post #928 of 7255 Old 09-06-2008, 06:50 PM
Chad T's Avatar
Originally Posted by Chad T View Post
...will the Edge offer any adjustments to switch from standard to PC levels? Or can you switch between RGB, YCbCr, etc.
Any word on this?
Have an Onkyo 805 receiver and having trouble setting up Audyssey? HERE is a mini how-to.Click HERE to check out my comparison review of 5 different projection screen fabrics.
Chad T is offline
post #929 of 7255 Old 09-06-2008, 07:37 PM
Joseph Clark's Avatar
Quoted: 272 Post(s)
Liked: 319
Any word on this?
I didn't see any reference to it anywhere in the pdf users manual, so my guess is that it doesn't distinguish between PC and video levels. I'd sure like to hear it from Josh, though. I ordered an Edge from Jason Turk here at AVS. That said, it's less of an issue for me, now that just about everything I have outputs video levels - even the Radeon 4850 video card I installed recently. Reports I read here on AVS said that the ATI-supplied DVI to HDMI dongle force the card to video levels. That sure does seem to be the case. Not to mention that it ouputs PCM audio over HDMI.
Joe Clark
Joseph Clark is offline
post #930 of 7255 Old 09-06-2008, 11:05 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3035
Interesting stuff.
Would be happy to trade my VP50 for the EDGE...
oink is offline
Reply Video Processors
