DVDO EDGE !! - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #1441 of 7262 Old 10-07-2008, 02:49 PM
eiren's Avatar
If todd612 is a registered user, he can log in using his telephone number (from the NDA) as the password.
If anyone is desperately trying to get some help/support from DVDO, then use the following address:
ken [at] anchorbaytech [dot] com
That will get you through to Ken Nguyen, head of National Sales & Support.
eiren is offline
post #1442 of 7262 Old 10-07-2008, 02:59 PM
cpcat's Avatar
joerod, you know the edge auto switches to PC levels for any non-TV resolution input, right?
cpcat is offline
post #1443 of 7262 Old 10-07-2008, 03:01 PM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
That doesn't help with football which is either 720p or 1080i though... It only does Video unless I am missing something...
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #1444 of 7262 Old 10-07-2008, 03:13 PM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
cpcat, PM sent...
joerod is offline
post #1445 of 7262 Old 10-07-2008, 03:58 PM
cpcat's Avatar
Yes, you are correct. Why do you want PC levels for these signals? Are you using a FLEA?
cpcat is offline
post #1446 of 7262 Old 10-07-2008, 04:03 PM
HDgaming42's Avatar
Quoted: 169 Post(s)
Because he wants it to look "punchier".
HDgaming42 is offline
post #1447 of 7262 Old 10-07-2008, 05:13 PM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Hell yeah! I love the extra "pop" I get when doing PC (only for sports though) under RGB. Remember, I am an eye candy extremist!
joerod is offline
post #1448 of 7262 Old 10-07-2008, 05:57 PM
UHD Addict
aaronwt's Avatar
Quoted: 6404 Post(s)
Liked: 3960
Originally Posted by jpb123 View Post
I'm pretty sure mine came in a brown cardboardbox inside an outer box I've thrown away. Don't think the outer one was a graphic one like yours. I think I would have saved it if it was.
As for FW while it changed to 1.0 at some time I'm sure it was 0.something from the beginning
Yes brown box, no pretty packaging but it has the standard DVDO packaging like I've had with all their scalers I've owned.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #1449 of 7262 Old 10-07-2008, 05:58 PM
UHD Addict
aaronwt's Avatar
Liked: 3960
I am using a Flea(broadcast sources only) with the EDGE and have a superb picture.
post #1450 of 7262 Old 10-07-2008, 07:32 PM
Bear5k's Avatar
Turn up your brightness. It's basically the same. All that PC levels change vs. video levels are the signal levels that define white and black. There shouldn't be anything magic, unless your displays or source gear are poorly engineered.
Color accuracy evangelist and CalMAN insider
Bear5k is offline
post #1451 of 7262 Old 10-07-2008, 08:14 PM
HiHoStevo's Avatar
Aaron.........
Would you mind posting your Edge settings for SDTV, SD-Movies, and HD-Movies?
Game Boxes also if you use them....
Steve
There are just two theories for successfully quarreling with a woman -- neither one works!
The Barn - Use Password = AVSForum
HiHoStevo is offline
post #1452 of 7262 Old 10-07-2008, 08:21 PM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Yes, my Sony VW200 is poorly engineered...
It has more to do then just turning up the brightness... Maybe I should check out a Flea...
joerod is offline
post #1453 of 7262 Old 10-07-2008, 08:45 PM
stretch437's Avatar
CalMAN insider? you're saying a gamma curve that is completely blown to hell can be fixed by turning up brightness a couple clicks? or did i miss some kind of humor here?
stretch437 is offline
post #1454 of 7262 Old 10-07-2008, 08:52 PM
HiHoStevo's Avatar
Don't know if it will help any Joe..... I had my Bernese Mountain Dog sit both in front of the projector and also on top of the Edge... could not see a lot of improvement and he had tons of Flea's.
post #1455 of 7262 Old 10-07-2008, 09:33 PM
skipsterut's Avatar
Lurking on this thread and trying to learn the ropes about VP's for a future purchase, so excuse my ignorance, but (other than an itchy little critter) what is FLEA?
skipsterut is offline
post #1456 of 7262 Old 10-07-2008, 11:01 PM
Pia-chan's Avatar
Originally Posted by scsiraid View Post
Ive added a few more pics. Lots of fingerprints
Thanks. You definitely have 'production' packaging...don't know about the faceplate, though
"Good wine is a necessity of life for me" -- Thomas Jefferson
Pia-chan is offline
post #1457 of 7262 Old 10-07-2008, 11:05 PM
Pia-chan's Avatar
Was it really necessary to post his address on this forum?
I'm sure he is luv'n you right about now...
Pia-chan is offline
post #1458 of 7262 Old 10-07-2008, 11:18 PM
JoshA's Avatar
Does anyone know for sure Josh has left DVDO?
I am no longer with DVDO.
I would like to thank everyone for the support that they helped provide to the products that I managed (iScan HD+, iScan VP20, iScan VP30, iScan VP50, iScan VP50PRO and EDGE). You may see me posting from time to time but it won't be as a representative of DVDO/Anchor Bay.
For all those customers, beta testers and resellers that I have built relationships with over the years you can still reach me by sending me a PM or an email.
Best Regards,
Josh Allen
My opinions are my own, and do not necessarily reflect those of my previous or current employers.
JoshA is offline
post #1459 of 7262 Old 10-08-2008, 12:32 AM
o27
o27's Avatar
Unbelievable - Pia-chan, in what way are you affiliated with DVDO?!
It seems that every single time something sligthly negative or even, in this case some kind offering of help, you´re all over the place, acting as some kind of insane watch-dog - how come?
If DVDO really had anything against any of the response and knowledge been spilt over in here, i would presume they would have enough manpower to appoint some staff to respond.
I really dont see how that can be your job?
o27 is offline
post #1460 of 7262 Old 10-08-2008, 01:14 AM
eiren's Avatar
That's been his entire contribution so far... hall monitor
Josh, good luck to you mate. Wish you all the best.
eiren is offline
post #1461 of 7262 Old 10-08-2008, 01:37 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Josh, it has been a great time and I guess all of us here wish you all the best for the future!
Fudoh is offline
post #1462 of 7262 Old 10-08-2008, 01:57 AM
iMbEst's Avatar
Originally Posted by todd612 View Post
I've been holding off this post for too long... partly because I don't know if I'm breaking any agreements by posting here.
Well, I'm one of those beta testers here and have received my unit a month ago. First, the Edge works beautifully. Just that I have several technical issues and needed some support. For a month now, I have not received any response from their technical support including Josh. I have placed calls to their 888 tech support, emailed edgesupport@dvdo.com and CC Josh directly. At the moment, I am very disappointed with their service.
how's the response from their beta tester forum?
iMbEst is offline
post #1463 of 7262 Old 10-08-2008, 04:05 AM
dlm10541's Avatar
What response? He said hes never gone there
dlm10541 is offline
post #1464 of 7262 Old 10-08-2008, 05:12 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
I'd like to thank Josh personally for all of his contributions to AVS. I am not sure how DVDO could let him get away when he is an obvious asset to them. Whoever attempts to take his place here on the Forum will have some really BIG shoes to fill. Goodluck Josh and I hope to see you around here...
joerod is offline
post #1465 of 7262 Old 10-08-2008, 05:33 AM
UHD Addict
aaronwt's Avatar
Liked: 3960
Algolith FleaHDMI - Time to iron out the facts?
post #1466 of 7262 Old 10-08-2008, 09:14 AM
Pia-chan's Avatar
i'd like to thank josh personally for all of his contributions to avs. I am not sure how dvdo could let him get away when he is an obvious asset to them. Whoever attempts to take his place here on the forum will have some really big shoes to fill. Goodluck josh and i hope to see you around here...
+1
Pia-chan is offline
post #1467 of 7262 Old 10-08-2008, 09:21 AM
Blacklac's Avatar
Since this unit had a lot of hype/talk, i guess it is a good thing there isn't much going on in here after units have been shipped and NDA's end? I take that as the unit works as expected and lives up to the results that are expected of the ABT, based on the VP50 and Oppo 983?
or are orders just not filled yet?
Blacklac is offline
post #1468 of 7262 Old 10-08-2008, 09:29 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Actually all of that is answered in recent pages of this thread.
Gary J is offline
post #1469 of 7262 Old 10-08-2008, 09:48 AM
Bear5k's Avatar
Check out a flea if you want, but the "pop" you are describing is most likely the result of the change in perceived brightness caused by level compression or expansion, depending upon how you have things configured on the input and output side.
I've posted this before in several places, so let's try this again to see if people understand the lack of magic here. How most VPs work (including The Edge):
  • Input levels matched to output levels (PC-PC, Video-Video): no change
  • PC levels in, Video levels out - Level compression (0 - 255 remapped into 16 - 235) - this is probably your increase in perceived "pop", but it will crush detail and fine gradations (more content, smaller bucket)
  • Video levels in, PC levels out - Level expansion (16 - 235 remapped to 0 - 255) which obviously gets rid of BTB/WTW information, which may be a problem if you are daisychaining multiple processors
The issue is what happens to the reference black and white levels, since the legal ranges (PC: 0 - 255, Video: 1 - 254) are fairly close. Personally, I'd just leave it on input levels being matched to output levels, and then tweak my PC accordingly (or bypass the VP altogether with the HTPC).
You probably missed a reading comprehension class or two, and definitely a class or five in civility and manners. See above. Gamma curves have nothing to do with it when you start doing level expansion/compression. If you don't want a molested signal, then leave the levels issue alone.
Bear5k is offline
post #1470 of 7262 Old 10-08-2008, 09:53 AM
GKevinK's Avatar
I haven't seem many "I received mine" type of posts... but FWIW I placed my preorder on the last day (per the original announcement) and the shipment tracking suggests it should arrive tomorrow. I guess that most of the preorders are either in peoples hands or should be very shortly.
GKevinK is offline
Reply Video Processors
