Switching multiple sources over a long distance - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-24-2009, 05:28 PM - Thread Starter
hiprecked's Avatar
Quoted: 24 Post(s)
I am designing a conference room that will have two Sharp 65" LCD panels in it. We are doing the LCD panels instead of the traditional projectors.
The conference table will have three spots to connect laptops and we also may have an input into the system for a Blu-ray player.
The LCDs will be up to 60 feet from the laptops on the table (due to cabling going under the table, up a wall, and over.
I've looked at the twisted pair options to do this (including the switching). I'm trying to learn more about the best way to do this (manufacturer and models). Extron is one of the companies that sell this type of gear.
Our main concern is switch laptops with different resolutions to the LCD panels. Should be let the LCDs handle and scale the input or should we put a switch in between that can do the scaling to the resolution of the LCD (1920 x 1080)?
An example transmitter receiver from Extron is at http://www.extron.com/product/produc...01&subtype=215
Thanks in advance for your ideas
hiprecked is offline
post #2 of 4 Old 06-25-2009, 08:33 AM
Jason Turk's Avatar
First off, which type of output are you planning for the laptops? That will make a difference. Generally a switch is the simplest thing. But, you will likely use HDMI for the Bluray, and though the newest laptops have HDMI out, it is not the majority of them. VGA switches would work fine for the laptops, but not the BluRay. The other tricky part is that VP's don't usually have 3 VGA inputs, so that might not work either.
Jason Turk is offline
post #3 of 4 Old 06-25-2009, 09:41 AM
sidb's Avatar
Surely anyone whose laptop doesn't support some kind of digital video output wouldn't be bringing it to such a fancy conference room. Let VGA die.
sidb is offline
post #4 of 4 Old 06-25-2009, 11:39 AM
RandyFreeman's Avatar
The Lumagen RadianceXE and HDQ video processors have plenty of connectivity for your conference room system. These units are installed in many classrooms and conference rooms. Rack mount ears are available for both units.
The Radiance has two HDMI outputs to drive the two monitors. It has six HDMI inputs. There are four component inputs. The input type for component input 10 can be set to RGBHV (VGA) to connect a laptop.
http://www.lumagen.com/testindex.php...diance_details
The HDQ has a DVI and a analog output. It has four DVI inputs. The DVI inputs can also be set to RGBHV (VGA) input. There are two component inputs.
http://www.lumagen.com/testindex.php?module=hdq_details
Contact us if you would like to discuss your application.
Randy Freeman
support@lumagen.com
503-574-2211
RandyFreeman is offline
Reply Video Processors
